04-17-2017, 02:09 PM
#461
Radio Code
Just changed battery for first time in a few years on my '99 Looked under hood, but no radio code indicated.
Standard CDR 220 type 4462
SN X5024402
Thanks in advance for any help Heiko. True ambassador for all things Porsche!
Kevin
1999 Porsche Boxster
Base 2.5L 64,000 miles
Arctic Silver / Black Interior / Guards Red Calipers
04-18-2017, 05:20 PM
#462
Heiko,
Can you help with code for this cdr 220?
Model BE 4362. Ser# 15031651
04-19-2017, 04:06 AM
#463
Originally Posted by Deadeye
Heiko,
4507 should work just fine for that radio :-)
Heiko
https://greatcyclechallenge.ca/Riders/HeikoVoss
Previously owned:
04-19-2017, 04:08 AM
#464
SN X5024402
Kevin
Try 7297 first for your radio and if that doesn't work try 7296... for some of these the code seems to fall right on the line of one or the other :-)
Cheers
Heiko
Previously owned:
04-19-2017, 07:20 AM
#465
I have 2 radios that I don't know the codes for. The four number codes are written in the frunk but I can't tell in which order to input them. Both radios are model 4462.
Ser.# W5002288 (code #'s appear to be 2, 6, 8, & 7 )
Ser.# Y5037406 ( code #'s are 8, 6, 8 ,& 7)
Can anyone put these codes in the proper order? Thanks
04-19-2017, 07:48 AM
#466
radio code
Good morning:
New member. Anyone have a radio code for my 2000 Porsche Boxster - 2.7 cyl
The type number is 4462 and the serial # for the radio is 15004161.
Any help would be appreciated.
Hans
Reason: error
04-19-2017, 07:52 AM
#467
1995 Porsche C4 Cab
04-19-2017, 08:32 AM
#468
Sarah's Tool
Tired of looking for radio codes
Hi, this is my first time posting on here. My wife's 2000S had a dead battery and now, with the new battery installed, the radio won't work. Not cool.
It apparently wants a code entered, but where in the car's manual does it show you the freakin' code? How do I get this mysterious code?
Thank you,
Sarah's Tool
Sarah's Tool
2000 Boxster S - the Black Bullet
04-19-2017, 11:56 AM
#469
Hey Heiko,
can you help me too?
CDR-220
Type 4467
SN 15004563
Porsche gave me wrong code, now i entered wrong one 3 times - hope WAIT will go away :X
04-19-2017, 05:58 PM
#470
two codes are up for this one 2687 and 2676 (try them in that order)
two codes come up for this one as well 3175 and 3174 - try them in that order
If that doesn't work email me back
Heiko
Previously owned:
04-19-2017, 05:59 PM
#471
Originally Posted by hans kater
Good morning:
Hans
Hans, your code is 4616
Heiko
Previously owned:
04-19-2017, 06:03 PM
#472
Thank you,
Sarah's Tool
LMAO
Well the code usually comes on a little radio card that comes with the radio, or in a few cases I've seen it stuck under the front or rear trunk lids by the dealers.
Anyhow if you do the following you can get the code as well....
Then msg me the serial and I can get you a code.
CR-220/CDR-220:
Turn off radio.
Hold down the TP button for at least 10 seconds.
Turn the radio on. "Becker 1" will be displayed.
Rotate the right knob slowly, as it will display the Becker model number.
Rotate again and radio serial number will display on radio display.
CR-210:
Press tone button then 8 and 0 simultaneously and "Becker" appears.
Press station up arrow on right, " PR-VERS" appears.
Press one of the numbered buttons below display, directly below the LCD arrowheads.
The model number will appear.
Press station button up arrow on right until, "SERIAL N" appears.
Press the numbered button again.
The serial number will appear.
Heiko
Previously owned:
04-19-2017, 06:05 PM
#473
Originally Posted by Chrisscho
Hey Heiko,
CDR-220
Type 4467
SN 15004563
Its a bit of a wait and if you leave it on continuously without shutting it off in between it will reset faster most of the time.
I'd be curious what code they gave you??? There are two codes that come up for that unit (like so many others)... 1st choice is 9438 and 2nd choice is 9336... the first one will probably work.
Heiko
Previously owned:
04-19-2017, 06:08 PM
#474
Originally Posted by Chuck W.
Chuck you're awesome  Thanks Bud
With any luck I'll get some more sponsors as I seem to have slipped into 7th place
H
Previously owned:
04-20-2017, 12:22 PM
#475
Sarah's Tool
Thank you Mr. Heiko.
I am off in search of the requested data and shall return here (theoretically) in good form.
Sarah's Tool
04-20-2017, 06:00 PM
#476
you are welcome... let me know if you have trouble getting the serial :-)
H
Previously owned:
04-22-2017, 07:06 AM
#477
You are the MAN Heiko!
I am in dire need of your powers.
'99
CDR-220
type 4462
X5028265
TIA
-Steve
04-22-2017, 08:10 AM
#478
Sarah's Tool
Hello Mr. Heiko:
Here's the dope: CDR220, GAL1, 4462, Y5034552, 24/99.
How'd I do?
Sarah's Tool
04-22-2017, 07:35 PM
#479
Hello Mr. Heiko:
How'd I do?
I see you got the info
try 9260 first and if that doesn't work try 9248
H
Previously owned:
04-22-2017, 07:36 PM
#480
'99
CDR-220
type 4462
X5028265
TIA
-Steve
The Magic ball says 5192 it is... LOL
H
Previously owned:
