Old 04-19-2017, 06:03 PM   #472
Heiko
Heiko's Avatar
Originally Posted by Sarah's Tool View Post
Hi, this is my first time posting on here. My wife's 2000S had a dead battery and now, with the new battery installed, the radio won't work. Not cool.
It apparently wants a code entered, but where in the car's manual does it show you the freakin' code? How do I get this mysterious code?
Thank you,
Sarah's Tool
LMAO
Well the code usually comes on a little radio card that comes with the radio, or in a few cases I've seen it stuck under the front or rear trunk lids by the dealers.
Anyhow if you do the following you can get the code as well....
Then msg me the serial and I can get you a code.
CR-220/CDR-220:
Turn off radio.
Hold down the TP button for at least 10 seconds.
Turn the radio on. "Becker 1" will be displayed.
Rotate the right knob slowly, as it will display the Becker model number.
Rotate again and radio serial number will display on radio display.
CR-210:
Press tone button then 8 and 0 simultaneously and "Becker" appears.
Press station up arrow on right, "PR-VERS" appears.
Press one of the numbered buttons below display, directly below the LCD arrowheads.
The model number will appear.
Press station button up arrow on right until, "SERIAL N" appears.
Press the numbered button again.
The serial number will appear.
Heiko
https://greatcyclechallenge.ca/Riders/HeikoVoss
Previously owned:
