10-13-2016, 05:43 PM
#401
Originally Posted by Zenster
Hi Heiko, the code worked! thank so much! I greatly appreciate you taking the time to help us all.
You are very welcome
Always nice to have tunes
Cheers
H
Previously owned:
11-28-2016, 10:17 AM
#402
Strange, I remove the PCM and it started with out any code. But manuy thanks again Heiko
12-04-2016, 03:34 PM
#403
No radio code card with car
Got the serial # 25014355. / 4462 / Becker 220
12-05-2016, 05:52 AM
#404
Its either 6921 or 6920 - try 6921 first
Heiko
Previously owned:
12-05-2016, 08:25 AM
#405
thanks , appreciate your efforts
12-18-2016, 08:00 PM
#406
1999 base
Hi Heiko.
Need your help with retrieving a code.
CCR-220
Model No. BE 6624
Serial No. 25006545.
Thanks in advance.
Meir.
12-19-2016, 05:34 AM
#407
Originally Posted by Meir
Hi Heiko.
CCR-220
Model No. BE 6624
Thanks in advance.
Meir.
Hey Meir, sorry I'm out right now but as soon as I get home later I will run the code for you :-)
Cheers
Heiko
Previously owned:
12-19-2016, 03:56 PM
#408
1999 base
Cheers
Heiko
Hi Heiko.
Thank you very much. No rush
12-19-2016, 03:58 PM
#409
Hi Heiko.
CCR-220
Model No. BE 6624
Thanks in advance.
Meir.
5230 or 5228 in that order :-)
Cheers
Heiko
Previously owned:
12-21-2016, 10:14 AM
#410
Originally Posted by Boxster_A
I have a 2002 Boxster with a Becker CDR 220 stereo, Type 4462, Serial # 25012241. I had to change my battery recently, and I seem to have lost my stereo code. I would appreciate any help. Thanks!!!
2301 or 2300 in that order - let me know if it doesn't work.
Sorry I missed this post
H
Previously owned:
12-21-2016, 04:34 PM
#411
1999 base
Cheers
Heiko
First one worked.
Thanks.
12-21-2016, 06:45 PM
#412
First one worked.
Thanks.
Glad it worked
H
Previously owned:
12-28-2016, 11:43 AM
#413
Porsche Rockie
New to the Boxster world. I was directed here by a member.
2001 CDR-220
model BE 4462
serial no. 15085827
I replaced the fuse in back of the unit and it powered up but sits in "WAIT" mode.
Any help very much appreciated.
Jim
12-28-2016, 06:07 PM
#414
Hi Heiko,
I found this forum via Google. I can't locate my owner's manual because my Boxster was in the shop for a full year! Long story but needless to say it needed a new battery and the radio is asking for the code. Following the instructions at the beginning of this post - this is my information:
Becker CR-220
Model 4462
Serial 25005888
To note on the serial - it *looks* like the second digit is a 5 and the fourth is a 0 (zero). The LCD on the radio is kind of not working right (e.g. some LCD elements are no longer lit) but it was working fine audio-wise before going to the shop.
Any help is sincerely appreciated!
01-02-2017, 05:50 AM
#415
2001 CDR-220
model BE 4462
serial no. 15085827
Jim
Did you try too many times to enter the code? It will come out of wait mode if its on long enough... 2828 should be your code but if that doesn't work try 2827
H
Previously owned:
01-02-2017, 05:52 AM
#416
Originally Posted by nychousehero
Hi Heiko,
Becker CR-220
Model 4462
Serial 25005888
Try 6910 first and if that doesn't work try 6899
Should work - let me know
Heiko
Previously owned:
01-02-2017, 08:22 PM
#417
Heiko
That worked and thank you! I can now see how bad the LCD on this radio was again.
Thank you for all the help.
01-02-2017, 08:33 PM
#418
I have PMed or emailed Heiko requesting several radio codes.... he has always come though. Class act .. Many thanks!
1995 Porsche C4 Cab
01-05-2017, 09:40 AM
#419
Hello all,
1st of all, happy new year!
I have just received a Becker CR-21, model BE 2160, serial number S1002205 (i am unsure the 1st character is a S or a 5?). Could someone please help me with the code?
Thanks a lot!
01-08-2017, 01:45 PM
#420
Porsche Rockie
H
Left it on for about an hour to get to the code. 2828 worked thanks for the help.
Jim
