06-26-2016, 05:38 PM
#321
[QUOTE=grc0456;501092]Heiko to the rescue!
Sent from my iPad using Tapatalk[/QUOTE...
Gosh I hope so !!!!!!
I need a hero right now !!!
06-26-2016, 05:39 PM
#322
Originally Posted by deja83
My well meaning husband replaced my battery......
I now have no radio.....This car is my second Porsche and I adore my baby !!!
I had to drive several states to get it used. No paerwork.
Its a 2001 Boxster S with a 3.2......gray and blue.....LOVE MY BABY !!!!
The radio is a Becker CDR 220
serial number Y5060377....
Does anyone have any ideas....?
I have already tried 1709,1617,1697,8687,5382,7371,5420,3234,9436,4948, 9621 and 8620.......I haven't hit the jackpot yet and would love to see her right again....many many thanks for someone can crack the secret code......
LMAO - none of those look like the right code.... not even close
Try 0938 1st and 0936 second... let me know if it doesn't work!
Heiko
Previously owned:
07-03-2016, 11:30 PM
#323
Boxster RADIO CODE . . . help . . . . ?
2000 Boxster S (LOVE THIS CAR!!!), just experienced a battery-change with an annoying side-effect . . . hostage-taking radio.
Tried 10 different codes . . .ugh
I BEG for help . . . .
Serial Y5042726
Thanks . . . :-)
Tomek
07-04-2016, 10:09 AM
#324
Originally Posted by tomekrondio@gmail.co
Serial Y5042726
Thanks . . . :-)
Tomek
8501 should work for you
H
Previously owned:
07-05-2016, 02:04 PM
#325
Heiko!!!
YOU ARE MY HERO!!!!!!!!
THANK YOU a million times . . . the code worked and life is good again!
All best to you!
Tomek
07-05-2016, 02:46 PM
#326
Heiko!!!
All best to you!
Tomek
Glad to help
Previously owned:
07-14-2016, 09:36 AM
#327
lost radio Code
Hi There,
Cab anyone please help with a lost radio code for the following;
1997 Boxster
Bleaker radio Model CDR 210
S/n V5007231
Many Thanks in advance.
07-14-2016, 10:21 AM
#328
Originally Posted by Karen Reynolds
Hi There,
1997 Boxster
S/n V5007231
Try 1032 or 1022 if 1032 doesn't work
Heiko
Previously owned:
07-17-2016, 12:40 PM
#329
And yet another lost Boxster radio code.........
I am a 'newbee' to this forum so please be gentle!!!!
I have read the above posts but don't see an answer to my specific problem.
My radio is a CR220, Becker 1, 4362, s.n. W5002947. I also have the remote CD changer.
Like everyone else, after changing batteries, I lost the radio code. I got the 4 **** and foolishly tried to enter a code which was incorrect. The wait message had now been displayed for HOURS, not allowing another code to be entered.
I would love to have the Correct code for my radio. Also, if anyone know a trick to resetting the message on the radio face, I would appreciate it. I tried to remove the battery cable again, but that did not luck.
My Boxster is a 2000. Thanks for the help!
07-17-2016, 12:43 PM
#330
Try 4607 first and if that doesn't work use 4605... one of those two codes should work.
Heiko
Previously owned:
07-17-2016, 12:51 PM
#331
Thank you very much! Any idea on resetting the Wait message? Like I said, it has been hours?
07-17-2016, 02:35 PM
#332
Radio code
Battery died. I don't use the radio much, I like the engine sound ant higher revs but it is nice to have
Vin WPOCB2986YU662150 cdr 220
Patrick
07-17-2016, 06:41 PM
#333
Make sure your battery is charged and leave the radio on for as long as 24hrs. If you've entered the wrong code more then once the time might get longer on some units.
But either way the unit has to be 'ON' in order to get past the timer....
H
Previously owned:
07-17-2016, 06:43 PM
#334
Patrick
I need the serial number for the CDR220 in order to get you the code.
H
Previously owned:
07-18-2016, 02:18 PM
#335
Radio code
where do I find the serial #???
If I need to remove the radio how does one do that??? Dempsey mentions special tools
thanks
Pat
07-18-2016, 07:18 PM
#336
thanks
Pat
CDR 220
• Turn off unit
• Push and hold the TP button for at least 8 seconds.
•Turn the unit on.... 'Becker 1' will show on display
• Rotate the right selector knob to display serial number
CR 210
• Press tone, then press 8 and 0 simultaneously 'Becker' appears
• Press station up arrow on right ' PR-VERS' appears
• Press one of the number buttons below display, directly below the LCD arrowheads
• The model number will appear
• Press station up arrow on right until, 'SERIAL N' appears
• Press the numbered button again
• The serial number will appear
Previously owned:
07-20-2016, 09:51 PM
#337
Sup guys I was wondering if you guys could help me with a radio code issue. Mines a 220 serial code is 15002106 type 4362. Also do you know why when I turn on the radio it just has me waiting forever ? I can't type any ode anymore even if I turn it on and back off after a while? Thank you in advance !!
07-21-2016, 08:19 AM
#338
Hi I need to disconnect the battery and do not have the code to activate the radio.
Becker type 1 4362
Ser: x5017231
Thanks in advance.
07-21-2016, 07:51 PM
#339
Becker type 1 4362
Ser: x5017231
Thanks in advance.
I sent you a reply to your PM
H
Previously owned:
07-21-2016, 08:01 PM
#340
Thank you heiko!!!
Many, many thanks. The info and code you provided worked great. Saved me a lot of anguish!
