04-22-2015, 04:29 PM
#101
Originally Posted by BobSC
Have a 1999 Boxster. Had to replace the battery. Need the unlock code for the CDR220 radio. Serial number is X5017740. Thanks!
BobSC - 1109 should work for you :-)
Cheers
H
Previously owned:
05-06-2015, 10:07 PM
#102
Hey thank God! Finally might be able to listen to the radio! OK......, Becker model number is be2182 and the serial # is w5010248. a new member to the forum and would greatly appreciate if someone could help me out between that code thank you keep up the great work!
05-06-2015, 10:09 PM
#103
michaels1law is online now Report Post
05-07-2015, 03:55 AM
#104
You can try 2737 - but I haven't had much luck with the old cassette units.
H
Previously owned:
05-07-2015, 07:23 AM
#105
Rburro2
I just bought a 2000 Boxster. The stereo is working presently, but being the 4th owner I do not have the owners manual or stereo manual. Is there a way to find or reset the code before I have an issue and need to remove it to get the SN?
Reason: Got answer under another topic
05-07-2015, 09:39 AM
#106
Rburro2
Type: 4462
CDP: 2081
SN: Y5038252
2000 Boxster 2.7- First Porsche Owned
05-07-2015, 10:50 AM
#107
RBURRO2 - 1504 should be the code for your radio.
Always handy to have it before hand
Previously owned:
05-07-2015, 01:33 PM
#108
Rburro2
Thank you..Heiko
05-10-2015, 05:18 PM
#109
Cdr220
Type 4462
Serial 15064634
05-10-2015, 05:34 PM
#110
Originally Posted by JaySea20
Cdr220
Type 4462
Serial 15064634
0721 is your code
Previously owned:
05-21-2015, 07:23 AM
#111
Lost radio code 2002 Porsche boxster
2nd owner with no code. Battery died and need code
CDR220
Model BE4462
Serial number 15003543
05-21-2015, 09:12 AM
#112
CDR220
Model BE4462
9864 and you should be good to go!
Previously owned:
05-23-2015, 10:21 AM
#113
Need code
220
4462
Y5043640
Thank you in advance.
Ryan
05-24-2015, 09:30 PM
#114
Help please
Fixed horn lost radio.
CDR-220
Type 4462
Ser X5026924
I follow a youtube video on how to fix sensitive horn that hunks with pot holes and hard braking. Steps included disconnecting battery and I can tell you this step was not needed and caused radio reset thus need for code.
Also the steps included adding O-rings on the top of metal bracket but indeed they should be placed behind it to put some distance between bracket and metal connectors that activate horn.
05-25-2015, 04:22 AM
#115
Originally Posted by McAlister91
220
4462
Y5043640
Ryan
0465 for your radio
Heiko
Previously owned:
05-25-2015, 04:24 AM
#116
CDR-220
Type 4462
Ser X5026924
7098 for your radio
Heiko
Previously owned:
05-25-2015, 10:01 AM
#117
7098 for your radio
Heiko
Many thanks.
05-25-2015, 02:42 PM
#118
My turn to ask. I tried the links to no avail, so here's my humble submission:
CDR-220
Model No: BE 4462
Serial No: X5023612
Thanks in advance.
Brian
05-30-2015, 11:54 AM
#119
Need Code
Here's the info I have...Thanks in advance!
CDR-220
Model BE 4462
Serial #: Y5044934
Bar Code: 4462G90Y5044934
06-01-2015, 10:11 PM
#120
Are you able to do the CR-210 also?
Model: BE2182
Serial: V5004929
Thanks in advance!
