Old 03-27-2015, 02:41 AM   #1
Heiko's Avatar
Originally Posted by beemanbill View Post
Hi, looking for the code to work my Boxster radio please. CDR 220, BE4462, Serial # Y5043688.
For the above info provided Try 5423
Previously owned:
Old 03-27-2015, 04:20 AM   #2
Bookmarked. I replaced the battery at the end of the season before putting mine away and the code needs to be reset.
cardiffgiant is offline   Reply With Quote
Old 04-03-2015, 01:02 PM   #3
Need help with finding the code for my radio
Type 4462
Serial 15008647
JoeB is offline   Reply With Quote
Old 04-03-2015, 05:01 PM   #4
Heiko's Avatar
Type 4462
Serial 15008647
9754 should do the trick
Previously owned:
Old 04-04-2015, 08:43 AM   #5
INFOSEC Ninja
AaronF's Avatar
Can you help a guy out?
Type 4462
Serial 15061805
You're the best! Can't believe I didn't know about this forum before!
AaronF is offline   Reply With Quote
Old 04-04-2015, 01:38 PM   #6
Heiko's Avatar
Type 4462
Serial 15061805
6492 should be the code for your radio
Heiko
Previously owned:
Old 04-04-2015, 06:54 PM   #7
INFOSEC Ninja
AaronF's Avatar
Thanks! That fixed it!
Old 04-05-2015, 01:32 AM   #8
Thanks Heiko
Old 04-22-2015, 02:28 PM   #9
Need Code
Have a 1999 Boxster. Had to replace the battery. Need the unlock code for the CDR220 radio. Serial number is X5017740. Thanks!
BobSC is offline   Reply With Quote
Old 04-22-2015, 03:14 PM   #10
On the slippery slope
JayG's Avatar
*** deleted***
2004 996 Targa Tip
Instructor - San Diego region
Old 04-22-2015, 03:29 PM   #11
Heiko's Avatar
BobSC - 1109 should work for you :-)
Cheers
H
Previously owned:
Old 05-10-2015, 04:18 PM   #12
Cdr220
Type 4462
Serial 15064634
JaySea20 is offline   Reply With Quote
Old 05-10-2015, 04:34 PM   #13
Heiko's Avatar
Originally Posted by JaySea20 View Post
Cdr220
Type 4462
Serial 15064634
0721 is your code
Previously owned:
Old 05-21-2015, 06:23 AM   #14
Lost radio code 2002 Porsche boxster
2nd owner with no code. Battery died and need code
CDR220
Model BE4462
Serial number 15003543
Mceddy0815 is offline   Reply With Quote
Old 05-21-2015, 08:12 AM   #15
Heiko's Avatar
CDR220
Model BE4462
9864 and you should be good to go!
Previously owned:
Old 05-25-2015, 01:42 PM   #16
My turn to ask. I tried the links to no avail, so here's my humble submission:
CDR-220
Model No: BE 4462
Serial No: X5023612
Thanks in advance.
Brian
jbm911 is offline   Reply With Quote
Old 05-30-2015, 10:54 AM   #17
Need Code
Here's the info I have...Thanks in advance!
CDR-220
Model BE 4462
Serial #: Y5044934
Bar Code: 4462G90Y5044934
jakeway is offline   Reply With Quote
Old 06-01-2015, 09:11 PM   #18
Are you able to do the CR-210 also?
Model: BE2182
Serial: V5004929
Thanks in advance!
leafdude555 is offline   Reply With Quote
Old 06-02-2015, 06:41 AM   #19
Heiko's Avatar
Model: BE2182
Serial: V5004929
Thanks in advance!
If it takes it, it will be 1103 .... Let me know.
Heiko
Previously owned:
Old 06-04-2015, 09:38 AM   #20
Boxster Radio code
Need help retrieving radio code on 2000 Boxster
Serial # y5034473
4462 any help is appreciated
ChrisBoggess1 is offline   Reply With Quote
