05-29-2014, 07:04 AM
#61
Thanks for the reply JayG,
I tried the web link a couple of times on different browsers and it just wont run correctly for me. Keep getting an error on the page after allowing Java to run.
05-29-2014, 08:35 AM
#62
Java ia a PITA
try 5420
05-30-2014, 01:35 AM
#63
Heiko
Thank you! Your code worked. Thanks very much, hugely appreciated!
06-17-2014, 01:09 PM
#64
Working on repainting my dashboard console and had to remove the radio, do I need to re-enter the code after installing the radio back?
Type # 4362
Serial # 15050567
06-17-2014, 01:58 PM
#65
try 0541
should work....
Type # 4362
Serial # 15050567
Previously owned:
06-17-2014, 02:00 PM
#66
Type # 4362
Serial # 15050567
If it is not a CDR23 or 24 and you disconnect power, most likely you will need to enter the radio code
See post #55 or 60 above for a link to get the code
06-17-2014, 03:12 PM
#67
Originally Posted by Heiko
try 0541
should work....
Yep, that worked. Thanks Heiko.
06-19-2014, 01:05 AM
#68
I also got stuck on the Becker code after changing the battery
Becker 1, type BE 4467, X5021650
Can someone help me on this?
06-19-2014, 04:51 AM
#69
Look at the posts above and try the link
06-26-2014, 04:33 PM
#70
Help Please like several others here I too require the radio code for my 2000 Boxster. The radio is the CDR-220 and the serial number is as follows: Y504022924/99. Does anybody know that code?
Thank you!
06-26-2014, 04:57 PM
#71
For serial Y504022924 code is 0839
Thank you!
Previously owned:
07-02-2014, 03:55 PM
#72
Need help finding out my code
Serial:x5016203
model:4462
07-02-2014, 10:07 PM
#73
Serial:x5016203
model:4462
Look at post #55 or 60
There is a link and it will give you the code
07-02-2014, 11:03 PM
#74
I need radio code for 1999 Boxster
I need codes for 1999 Boxster
Becker 1
Type 4462
Serial:X5020053
48/98
CDP2081
thanks
07-03-2014, 06:37 AM
#75
Becker 1
Type 4462
Serial:X5020053
48/98
CDP2081
thanks
Have you tried reading this thread? Even the post just before yours?
Give it a try before asking for someone to do the work for you
Or go to the dealer and they will give it to you. Of course,they will probably charge you to do it
Do I mind generating a code, no. But do a little research first. It seems many of the code requesters it is their first post, or 2nd or 3rd. At very least read the very thread you are posting in !
Everyone here ( well most) is/are happy to help. You will learn more about your car with a little reading
I like most on this forum have spent a lot of time looking through the threads before asking for help.
Don't be lazy.
If you can't find the answer, or it did not work, by all means ask for help.
Ok, off my soapbox
07-03-2014, 07:11 AM
#76
I tried the link a zillion times and it gives an error so thats why i posted it
thanks
07-03-2014, 12:02 PM
#77
i got it from another site - thanks anways
#78
thanks
No problem, should have said that in your post
The link requires JAVA and that sometimes causes problems
I'll be where I can generat the code for you in a few hours
07-03-2014, 04:00 PM
#79
Cool
What is the website you used?
08-05-2014, 05:27 PM
#80
Car was sitting for over a year with dead battery. Can you help me with a code for:
99 Porsche Boxster
CDR-220
Ser # x5028925
Model 4462
