Old 01-02-2016, 06:31 PM   #181
stelan's Avatar
Originally Posted by stelan View Post
Where is the code on my cdr220? There are no labels showing it on the outside
Anyone can help?
stelan is offline   Reply With Quote
Old 01-02-2016, 07:18 PM   #182
Heiko's Avatar
Originally Posted by mattjfox View Post
Hi,
I changed my battery and now need the radio code. Car is 2001 Boxster S.
Radio type is CDR-22.
Type code is 4467.
Serial number is Y5036184.
24/99.
Any help would be much appreciated.
Thanks, Matt.
Try 0836 if it doesn't work let me know.... sometimes those CDR-22's take a few tries.
H
Previously owned:
Old 01-02-2016, 07:19 PM   #183
Heiko's Avatar
Of course there is no code on the outside... are you talking about the serial number?
•Turn off radio
• Hold down the TP button for 10+ seconds
•Turn the radio on (Becker 1) will display
• Turn the right knob two notches, on the first notch it will display the Becker model number...
• Rotate one more notch and radio serial number will display on display
Previously owned:
Old 01-02-2016, 09:30 PM   #184
stelan's Avatar
•Turn off radio
Ah cool, thanks
Old 01-06-2016, 07:08 AM   #185
I have a 2000 Boxster and need the radio code, please help!!
CDR 220
Serial #Y5043551
The other number I got is 24/99
Jgrim008 is offline   Reply With Quote
Old 01-06-2016, 07:11 AM   #186
CDR 220
Serial Number Y5043551
Other number is 24/99
Old 01-06-2016, 07:57 AM   #187
Heiko's Avatar
CDR 220
8928 should do the trick.
H
Previously owned:
Old 01-06-2016, 08:04 AM   #188
H
Thank you worked perfectly
Old 01-16-2016, 10:56 AM   #189
Thom
Hey all. I've read through the entire post on the lost codes. I too have fallen into the trap of a second owner. the dude who had the car has done some extensive audio upgrades but left the factory unit. I followed the directions and gotten the following info; Can someone please tell me the code for this unit?
Type: 4462
S/N: CDP2081
Cheers!
Calmg0d is offline   Reply With Quote
Old 01-16-2016, 01:23 PM   #190
Heiko's Avatar
Type: 4462
S/N: CDP2081
Cheers!
Sure but that serial number isn't right for that 4462... call the serial up via the screen and you'll get the right number.
H
Previously owned:
Old 01-17-2016, 12:05 PM   #191
Thom
Updating this post because I haven't heard back in a while.
Would Heiko or anyone else be able to help??? I do appreciate it as I am currently tuneless, and although the sound of the engine is pretty cool, it gets old on the daily drive to work and back.
I went back and followed the procedures to get the SN and I think I got it right this time.
my SN should be X5033455 If this isn't the correct one then I really don't know what else to do by following the directions listed in previous posts to this thread.
I also got this number CDP2081 as well as 48/98, But I don't really know what those are.
Thanks for the help.
Thom
Old 01-28-2016, 09:20 PM   #192
I have a CDR-220 X5023591 4462 . I have tried 30-40 different number found on the interwebs with no luck. Any help would be appreciated.
Type 3 TJ is offline   Reply With Quote
Old 01-28-2016, 09:22 PM   #193
Old 02-01-2016, 05:31 AM   #194
Heiko's Avatar
Sorry I've been on vacation for a bit but I'll be back next weekend and can give you the code then. No access to my system from here.
H
Previously owned:
Old 02-02-2016, 02:07 PM   #195
Thom
H
No worries from me. I was able to get the code and my radio is back up and running.
Thanks anyway.
Old 02-03-2016, 12:31 AM   #196
Hi,
I just bought a nice 911 996 targa with a nice Becker cdr-22.
The problem is, the cdr-22 is asking for a code i don't have.
Could you please help me ?
CDR-22
type 4467
serial 25009747
Best regards,
Thierry
Cybertiti is offline   Reply With Quote
Old 02-06-2016, 11:29 AM   #197
Heiko's Avatar
Try 1063
H
Previously owned:
Old 02-06-2016, 11:31 AM   #198
Heiko's Avatar
Originally Posted by Cybertiti View Post
Hi,
CDR-22
type 4467
serial 25009747
Best regards,
Thierry
Try the following in order... if none of these work let me know.
2179, 1179 or 1131
Heiko
Previously owned:
Old 02-13-2016, 09:04 AM   #199
having trouble finding my code, would really appreciate the help!
2002 Boxster
CDR 220
Type: 4452
Serial: 25010695
Type: 4452
Thanks!
wily986 is offline   Reply With Quote
Old 02-13-2016, 09:11 AM   #200
2002 Boxster
CDR 220
Type: 4452
Serial: 25010695
Type: 4452
Thanks!
