Old 04-29-2013, 06:41 AM   #1
Safe spots to jack up a 2007 boxster?
Hello,
I have a 2007 boxster.
I have avoided changing the tires myself, but now I have to switch a rear tire.
I have several jacks and I even bought a hockey puck looking thing that sits on the jack and protects the underside of the car, what I don’t know are the safe-spots on the underside of the car. I don’t have a manual, can anyone point me to a diagram showing where to jack the car?
lurky is offline   Reply With Quote
Old 04-29-2013, 06:50 AM   #2
Boxster 1999
Check out Pelican tech info they show two spots at the rear where you can also lift or put candles. For your safety alway have two supports point!
Boxster 99
Barteur is offline   Reply With Quote
Old 04-29-2013, 07:14 AM   #3
ppbon's Avatar
Thew car has 4 jacking points ...
Originally Posted by lurky View Post
Hello,
... located just behind the front wheels and just ahead of the rears about 4" from the edge of the skits.
If you get on your knees you will clearly see them. They are reinforced points that can support the weight of the car.
Do not put your jack on any other point on the body since the weight will crush the panel.
BTW, here's your Owner's Manual:
www.Pedrosgarage.com/07Boxster.pdf
The information on lifting the car is on pages 258 and 259 of the manual.
Happy Boxstering,
Pedro
Racecar spelled backwards is: Racecar!
ppbon is offline   Reply With Quote
