Old 04-14-2013, 11:17 AM   #1
thom4782's Avatar
IMS Solution Installation Video
This is pretty cool.
If you had any doubts about components that make up an IMS Solution, this video will clear them up.
Installation Video | The IMS Solution
Old 04-14-2013, 01:00 PM   #2
tonycarreon's Avatar
probably self-evident, but where does the oil that's used to lubricate the bearing go, since there's only an incoming line?
Old 04-14-2013, 01:14 PM   #3
Theoretical propagandist
Eric G's Avatar
I am assuming it goes back into the engine and into the sump.
Old 04-14-2013, 02:31 PM   #4
There is a grove in the IMS solution insert that allows it to drain back into the sump via the rear of the shaft:
