Old 04-09-2013, 08:16 PM   #1
Joe B's Avatar
Frunk light question
Weird question: my frunk light doesn't come on unless I unlatch the trunk. Is this normal? Nothing I could find about trunk/frunk lights in the owner's manual. Does the frunk have a switch for the light?
Old 04-09-2013, 08:36 PM   #2
Frunk light should come on when frunk is opened. Not sure where the switch is, though. My guess would be in the latch mechanism somewhere.
Old 04-10-2013, 02:39 AM   #3
That light goes on when the lid is opened. Off when closed. If left open, it goes off after a delay. I put a simple toggle switch in my wiring, toggle next to the light. I rarely want or need that light.
leknus is offline   Reply With Quote
Old 04-10-2013, 04:25 AM   #4
Coffinhunter's Avatar
Do you really want the light on when the frunk is closed? What are you keeping in there that is afraid of the dark?
It is the same in my car anyway
Old 04-10-2013, 05:31 AM   #5
tonycarreon's Avatar
the only weird part is what led you to conclude this in the first place.
"ok jr, go lay down in the front trunk while i latch it..."
*click*
"IS IT OFF?"
Old 04-10-2013, 06:24 AM   #6
CoBeerToad's Avatar
Reminds me of the week I spent trying to figure out if the light goes off in the refrigerator when I close the door. You have to be real fast!
CoBeerToad is offline   Reply With Quote
Old 04-10-2013, 06:25 AM   #7
Joe B's Avatar
Come on, guys. Before you try to make me sound foolish, try reading my post a bit more carefully . I don't know how to make this more clear . When I open the frunk, the light does not come on. If I then unlatch (or open) the trunk, then the frunk light comes on. Tonycarreon, no conclusion here, simple observation. And Coffinhunter, I didn't say anything about what the light does when the frunk is closed. Now then, can anyone actually be of some help? Particlewave, thank you. Now if I can just figure out where the frunk light switch is...
Old 04-10-2013, 06:26 AM   #8
Joe B's Avatar
Please read my post again; this has nothing to do with when the frunk is closed.
Old 04-10-2013, 06:33 AM   #9
Ha!!!
Funny...
Old 04-10-2013, 07:11 AM   #10
thom4782's Avatar
Let me see if I understand your question correctly.
There are two conditions. Condition 1 - if you only unlatch the frunk, the frunk light stays off. Condition 2 - if you unlatch BOTH the frunk and the trunk, BOTH the frunk and the trunk lights come on.
Did I state the situation correctly?
Old 04-10-2013, 07:21 AM   #11
thom4782's Avatar
Maybe this thread from the Pelican forum will help....
Front Trunk Light Problem - Pelican Parts Technical BBS
Old 04-10-2013, 07:43 AM   #12
Probably doesn't help... but I use a batt. tender so my frunk is slightly open all the time. I unplugged the frunk light and layed it aside because I thought it was on all the time. I discovered that the trunk and frunk lights are connected. I worried about the trunk light being on all the time, but later learned that it goes off after a period of time. Still doesn't help your situation.... but you're right they are connected somehow.
Old 04-10-2013, 08:04 AM   #13
My `01 does the same. Along with the lid strut loosing gas. One evening, the lid slammed down.. And the light came on. The stuck switch is most likely the same one for the alarm. Suspect the switch to be by the latch.
Per parts catalog, it`s 996 613 206 00 called microswitch
sb01box is offline   Reply With Quote
Old 04-10-2013, 09:11 AM   #14
CoBeerToad's Avatar
Sorry. Was just trying to be funny.
Maybe this helps?
OK. It's kind of small. Try the link to the catalog. Illustration 803-00
Porsche Original Parts Catalogue - Parts and Diagnostic Information - Porsche Service - Dr. Ing. h.c. F. Porsche AG
Old 04-10-2013, 01:44 PM   #15
yes, i did not read carefully enough. now i understand your question. this is not normal. my '01 works as expected.
open frunk only - frunk light illuminates
open trunk only - trunk light illuminates
open both - both lights illuminate
open neither - no lights illuminate (i can only assume)
so do the interior lights come on when you open the frunk? have you done this with both the key fob and using the latch release in the cabin? same behavior?
Old 04-10-2013, 02:21 PM   #16
Joe B's Avatar
Lightbulb It fixed itself!
Thom4782, you got it right, and thanks for the link. Update: I sprayed silicone spray on the frunk latch mechanism and now the light works fine! CoBeerToad, thanks, I forgot I have the parts manual online.
Old 04-11-2013, 10:19 AM   #17
Beelzy's Avatar
Lol! I understand what the OP meant as I have the same issue. It is quite odd, and I hope
I have the same luck as him fixing the problem.
Cheers!
Beelzy is offline   Reply With Quote
