Old 04-07-2013, 02:19 PM   #1
Too much oil?
Did an oil and filter change yesterday. Only put in 8.25 quarts and the stick is reading a tad more than full. Will it burn off or should I drain some?
Old 04-07-2013, 02:24 PM   #2
Pull the filter housing, it holds about 1/2 quart.
Old 04-07-2013, 03:08 PM   #3
Will more than what's in the filter housing drain out?
Old 04-07-2013, 03:36 PM   #4
kjc2050's Avatar
Nope. My opinion, half a quart is a high estimate. More like 5-6 ounces.
Old 04-07-2013, 03:52 PM   #5
Cool, I didn't know that either. I just changed my oil and have been wanting to switch to the LN filter adaptor, now it will be a breeze and I can inspect the older filter.
grtc68 is offline   Reply With Quote
Old 04-07-2013, 04:42 PM   #6
schnellman's Avatar
The book my indy uses indicates about a quarter of a quart more than my owner's manual says. And, a couple of times he has added too much. I use a long plastic tube and siphon the extra oil out of the opening where oil would normally be added. Sucks, but it works.
Old 04-07-2013, 05:30 PM   #7
Airline tubing for a fish tank?
Old 04-07-2013, 05:46 PM   #8
kjc2050's Avatar
Dropping the filter takes 10-15 minutes start to finish, no siphoning, no oil dripping off a siphon hose.
Old 04-07-2013, 05:50 PM   #9
Definitely drain some. I personally prefer to have the level just below the full mark.
Keep in mind overfilling the oil level causes AOS failures.
2008 Boxster S PDE2
cas951 is offline   Reply With Quote
Old 04-07-2013, 07:57 PM   #10
DFW02S's Avatar
The tech guru for the local PCA suggests that if you track it, fill to the top of the orange marker.
DFW02S is offline   Reply With Quote
Old 04-08-2013, 03:25 AM   #11
I would be cautious about putting plastic tubing down either the oil fill or dipstick tubes (on cars with them) as there are a lot of sharp edged things the tube can get hooked on and make it nearly impossible to pull it back out. We have had to take a couple sump covers off cars whose owners tried to use commenrical vacuum tank systems to suck the oil out without jacking the car up. Bad idea..........
Old 04-08-2013, 03:57 AM   #12
schnellman's Avatar
That's what I've used successfully. Takes a a couple of minutes without having to get under the car. But, if it's a bad idea, I certainly don't want to cause anyone a problem.
Old 04-08-2013, 05:46 AM   #13
Dipstick or dash indicator?
Old 04-08-2013, 05:54 AM   #14
Randall, just wipe the dipstick 137 times. Done.
Old 04-08-2013, 07:23 AM   #15
CoBeerToad's Avatar
I got it!
CoBeerToad is offline   Reply With Quote
Old 04-08-2013, 07:32 AM   #16
DFW02S's Avatar
The dipstick
Old 04-08-2013, 05:45 PM   #17
Dropped the filter housing and dumped some oil. It does make a bit of a mess though, so have your oil catch pan handy. Thanks everyone for the great ideas!
Old 04-09-2013, 02:50 AM   #18
Always the path of least resistance......
Old 04-09-2013, 05:42 AM   #19
recycledsixtie
recycledsixtie's Avatar
This thread reminded me that my oil level was low- halfway between full and min. on the guage which I did on the last oil change. So be extra careful to avoid overfilling as it does not take much to overfill it. Yesterday I put a pint in and it moved the guage level to about 2 more bars. It is so easy to overfill it.
