04-07-2013, 03:19 PM
#1
Too much oil?
Did an oil and filter change yesterday. Only put in 8.25 quarts and the stick is reading a tad more than full. Will it burn off or should I drain some?
04-07-2013, 03:24 PM
#2
Pull the filter housing, it holds about 1/2 quart.
04-07-2013, 04:08 PM
#3
Will more than what's in the filter housing drain out?
04-07-2013, 04:36 PM
#4
Nope. My opinion, half a quart is a high estimate. More like 5-6 ounces.
04-07-2013, 04:52 PM
#5
Cool, I didn't know that either. I just changed my oil and have been wanting to switch to the LN filter adaptor, now it will be a breeze and I can inspect the older filter.
04-07-2013, 05:42 PM
#6
The book my indy uses indicates about a quarter of a quart more than my owner's manual says. And, a couple of times he has added too much. I use a long plastic tube and siphon the extra oil out of the opening where oil would normally be added. Sucks, but it works.
04-07-2013, 06:30 PM
#7
Airline tubing for a fish tank?
04-07-2013, 06:46 PM
#8
Dropping the filter takes 10-15 minutes start to finish, no siphoning, no oil dripping off a siphon hose.
04-07-2013, 06:50 PM
#9
Definitely drain some. I personally prefer to have the level just below the full mark.
Keep in mind overfilling the oil level causes AOS failures.
2008 Boxster S PDE2
02 Boxster S Blk on Blk(Stock for the Wife)
88 turbo S (My Toy) slightly modified
04-07-2013, 08:57 PM
#10
The tech guru for the local PCA suggests that if you track it, fill to the top of the orange marker.
04-08-2013, 04:25 AM
#11
I would be cautious about putting plastic tubing down either the oil fill or dipstick tubes (on cars with them) as there are a lot of sharp edged things the tube can get hooked on and make it nearly impossible to pull it back out. We have had to take a couple sump covers off cars whose owners tried to use commenrical vacuum tank systems to suck the oil out without jacking the car up. Bad idea..........
04-08-2013, 04:57 AM
#12
That's what I've used successfully. Takes a a couple of minutes without having to get under the car. But, if it's a bad idea, I certainly don't want to cause anyone a problem.
04-08-2013, 06:46 AM
#13
Dipstick or dash indicator?
04-08-2013, 06:54 AM
#14
Randall, just wipe the dipstick 137 times. Done.
04-08-2013, 08:23 AM
#15
   I got it!
04-08-2013, 08:32 AM
#16
The dipstick
04-08-2013, 06:45 PM
#17
Dropped the filter housing and dumped some oil. It does make a bit of a mess though, so have your oil catch pan handy. Thanks everyone for the great ideas!
04-09-2013, 03:50 AM
#18
Always the path of least resistance......
04-09-2013, 06:42 AM
#19
recycledsixtie
This thread reminded me that my oil level was low- halfway between full and min. on the guage which I did on the last oil change. So be extra careful to avoid overfilling as it does not take much to overfill it. Yesterday I put a pint in and it moved the guage level to about 2 more bars. It is so easy to overfill it.
