Old 04-26-2013, 08:49 AM   #1
CoBeerToad's Avatar
Finally got that stupid triple square bolt!
Ended up using a hex bit (I guess that is what you would call it). About 3 inches long. I put a 7/16" box end around it and jammed the bit in the bolt. Then I took a large broken screwdriver and put that between the bit and the final drive and hammered it in there wedging the bit in the bolt so it could not slide out and strip it. I had enough room on the front side to rotate the box end wrench.
Probably wasn't the "correct" way, but after taking this long and my level of aggravation, I didn't care anymore. Heading to the hardware store to find a replacement bolt as there is no way I am putting that stupid bolt back in there.
I think that should add at least $500 to the value of the car also!
CoBeerToad is offline   Reply With Quote
Old 04-26-2013, 12:42 PM   #2
woodsman's Avatar
I have the feeling your working on a 5-speed. Anyways you won in the end -damn Porsche!
Old 04-26-2013, 01:27 PM   #3
Homeboy981
Homeboy981's Avatar
Hi @CoBeerToad,
Try finding a nut to fit. Take out your tack welder or take it to a welding shop and have them "put a stem" on it for ya.
Viola! New Porsche tool!
(the 'stick out tongue' thing was intended for the Pcar engineer that designed that darn fitting)
Good Luck!
