Old 04-02-2013, 07:39 AM   #1
Pup
Strange Noise
I have noticed that at 1600-2000 rpms, in gear, moving in any gear, that I hear a howl, moan. It goes away after that rpm range. I have no idea where this may be coming from. It does not appear to be load dependant, but is rpm dependant..
2000 Boxster S 3.2
Any ideas?
bc
Pup is offline   Reply With Quote
Old 04-02-2013, 07:50 AM   #2
Nimbus117's Avatar
Have you had the IMS bearing replaced? I read something about moaning at low revs can be advanced warning of an IMSB failure. There are probably other things it could be but this is the most worrying.
On a different note, I had a moan at high revs when I was having fun. Tracked it down to the passenger seat so now I no longer let the wife in.
2003 Boxster 2.7L
2010 Civic Type R
Old 04-02-2013, 07:57 AM   #3
DFW02S's Avatar
Well done, that's the most effective way to neutralize the wide open throttle alarm.
DFW02S is offline   Reply With Quote
Old 04-02-2013, 08:18 AM   #4
Pup
low rpm moan - tell me more
IMS has not been replaced..
Tell me more.... about the low rpm moan issues?
Only occurs when driving "easy" like 1600-2000 rpm, pitch is constant, volume is constant, not loud , no grind, no change in tone/pitch/volume with rpm, just there or not there... Never heard on accelleration, mostly when driving low speed, 30-35 mph... Motor not lugging, no obvious issues. Just annoying and I'd like to make it go away.
Pup
Old 04-02-2013, 09:48 AM   #5
Nimbus117's Avatar
Not sure where I read it but it stuck in my mind. Just remember it stating than in rare occasions a moaning at low revs preceeded an IMSB failure.
I dont know if anyone can shed any light or offer alternatives but thought I had better tell you.
2003 Boxster 2.7L
2010 Civic Type R
Old 04-02-2013, 11:07 AM   #6
Pup
Yes. Please chime in if you have any info.
PLease chime in if you know anything about this... I may have read something like that but was almost positive there was a vibration associated and that it occurred at start up . This does not. just in the range I stated.
bc
