Old 03-29-2013, 12:17 PM   #21
good points. Which sort makes me wish there was an LNE no-bearing upgrade for dual rows.
But I guess the money is with the single row sales.
LOL!!!! Yes the money was absolutely with the single row bearings. I just wonder where they found such a good deal on the oversized single row bearings?
I bet it fits some Czech tractor transmission that was obsolete in the 80's.
Skoot
Skootnasty is offline   Reply With Quote
Old 03-29-2013, 07:24 PM   #22
Originally Posted by BDBoxster View Post
WOW REALLY?????:ah:
YEAH! WOW REALLY!!!!!!!
Sheeessshhhh......... So sorry for my original post, I hope I didn't upset your personal life too much!
If I would have known that YOU would have had such pitiful surprise, I would have been more clear "just for you"
and put into details, that I was up early and I had not yet put in my contact lenses and was having a hard time seeing my screen. WTF?
986Porsche986 is offline   Reply With Quote
Old 04-10-2013, 01:49 PM   #23
I should have done more research (about 5 minutes worth) before posting. Search "VIN" decoder before referring to VIN list posted regarding single vs. double row.
Last edited by jotoole; 04-14-2013 at 02:07 AM. Reason: should have done more research
jotoole is offline   Reply With Quote
Old 04-10-2013, 02:44 PM   #24
Originally Posted by Ckrikos View Post
Not trying to scare anyone, but dual row bearings have failed too, though to a lesser extent.
Lesser extent is an understatement. Less than 1% vs. 8-10%. There are many motors from many manufactures that have engine failures near 1%. And as for the argument that the more bearings mean more metal particles in your oil, not so much. If your double bearing is shearing off slivers of metal, it will totally fail at some point so I don't think this a big issue due to the less than 1% failure. With the current stats that Porsche has released, I think if you have a double bearing engine, you can rest easy! The double bearing engines are no more likely to have total engine failure than any other performance motor. I'll think about changing mine when I need a new clutch. Until then, I'm not going to give my IMS a second thought!:dance:
Meat Head is offline   Reply With Quote
Old 04-11-2013, 07:07 PM   #25
darknight's Avatar
I'm just wondering where the failure rate statistics are found? I have seen a lot of numbers thrown around, in regard to IMS failures, and they all seem like here-say.
Regardless of the actual numbers though, this is a well-documented shortcoming of these motors. And given the motor replacement cost, it almost seems like a no-brainer, to have this bearing upgraded, when it is either convenient or financially feasible, unless you are the gambling type.
darknight is offline   Reply With Quote
Old 04-11-2013, 07:31 PM   #26
Chuck W.'s Avatar
My 2001 S has a build of 03/2001. BUT.... it falls is this area of single rows; WP0CB29802U660062 - WP0CB29892U664319.
1995 Porsche C4 Cab
Old 04-13-2013, 04:05 AM   #27
Originally Posted by 986Porsche986 View Post
It must be too early in the morning for me, I can't seem to figure out where my vin fits in here. Can someone help me out?
My 2002 S VIN= WP0CB29852U663832
It's morning. Still workin' on my first cup of joe. And I do appreciate your confusion...
Once again, Porsche has made things more confusing than is necessary, IMHO anyway. For starters, WHY do they have some of the ranges in ascending numerical order and some in descending order?
Secondly, they have some ranges that are, to varying degrees, duplicates, ie that seem to be overlapping. What's the logic in that?
I sort of wonder if they're just being recalcitrant (ie difficult) in their responses to requests for discovery at trial maybe?? Whatever...
In any case, mine ('01 S) has a VIN that begins with: WPO CB29841
I would seem to be triple-whammied, since I would appear to fall in ALL 3 of these ranges...
o WP0CB29802U660062 - WP0CB29892U664319
o WP0CB29854U660061 - WP0CB29834U661824
o WP0CB29885U730069 - WP0CB29835U731310
Old 04-13-2013, 04:38 PM   #28
copsahl's Avatar
The Porsche supplied VIN data is sorted by model year with 01 on the top and 05 on the bottom. The three ranges you questioned are for 02, 04 and 05 models respectively.
copsahl is offline   Reply With Quote
Old 04-14-2013, 04:22 AM   #29
Maybe not..
Do a research of VIN,this site.
Look at 10th character.
Build date.
Your Box is not in that range.
Old 04-14-2013, 08:47 AM   #30
Chuck W.'s Avatar
Originally Posted by jotoole View Post
Maybe not..
Build date.
Hummmmm...... I believe you're right. The VIN range I was looking at was for 2002s; WP0CB29802U660062 - WP0CB29892U664319. Odd that my last six sequential numbers, 663867, are included in the 2002 VINs.
Thanks jotoole, I appreciate your help.
1995 Porsche C4 Cab
Old 07-29-2014, 05:18 PM   #31
Sorry to resurrect an old thread but the more I read the forum the more worried I get about the much talked about IMS failure. My Vin: WP0CA29841U621069 I don't believe lies in that range. Moreover, on the passenger door sill, the manufactured date states 09/00 in Finland which I believe is September 2000. This must mean my engine was manufactured before that. Is that any assurance that I could have a double row bearing? Losing sleep over this so finally decided to put it out there. Thanks.
2001 Seal Gray Boxster (Hair Salon on wheels)
2013 Audi Q5 (Family Mover)
2006 Yamaha R1 (Adrenaline Machine)
amitmishra4 is offline   Reply With Quote
Old 07-29-2014, 07:10 PM   #32
Chuck W.'s Avatar
Since my original posting I found a posting by Pelican. http://www.pelicanparts.com/techarticles/Boxster_Tech/14-ENGINE-Intermediate_Shaft_Bearing/14-ENGINE-Intermediate_Shaft_Bearing.htm
Below are their findings.
The engine number of my 2001 Boxster S with a 3/2001 build date is M96 21/ 671 09227. According to a Pelican Technical Article, this engine should have a double row IMS baring.
The class action lawsuit states that single row bearings have an 8% failure rate while the double row has a 1% failure rate.
Engine Number Model Bearing Type
Up to engine # M 651 12851 Boxster 2.7L M96.22 Double Row Bearing
Up to engine # M 671 11237 Boxster S 3.2L M96.21 Double Row Bearing
Up to engine # M 661 14164 Carrera 996 3.4L Double Row Bearing
From engine # M 651 12852 Boxster 2.7L M96.22 Single Row Bearing
From engine # M 651 11238 Boxster S 3.2L M96.21 Single Row Bearing
From engine # M 661 14165 Carrera 996 3.4L Single Row Bearing
All 2005 Boxster 987 (maybe some 2006 models) Single Row Bearing
All 2005 Carrera 997 (maybe some 2006 models) Single Row Bearing
Maybe some 2006 Cayman models Single Row Bearing
1995 Porsche C4 Cab
Old 07-29-2014, 07:37 PM   #33
Engine Surgeon
All of those numbers posted are to be taken with a grain of salt. We find discrepancies with them routinely here in the real world. In 2000 and 2001 the engine can be a single or dual row. In 2005 the engine can be an M96 single row or an M97 single row. Those years require a visual inspection to verify which bearing the engine is fired with.
The info for other, non change- over years is more accurate.
Not even the data from the class action suit is 100% correct.
US Patent 8,992,089 &
US Patent 9,416,697
Old 07-30-2014, 02:38 AM   #34
I understand that the visual inspection you mention will require pulling the clutch assembly amongst other things, right? Is there any alternate way to make this determination in the least intrusive way? Thanks.
Old 07-30-2014, 02:41 AM   #35
No...........
Old 07-23-2017, 05:36 AM   #36
Hello,
I hope someone can HELP.
I am very interested in buying a used 2000 Boxster , but am afraid of the IMS issue. Sticker says mfd 12/99. Can I supply the vin and can someone tell me if the car has the single or dual row IMS?
Thank you !
HJ47 is offline   Reply With Quote
Old 07-23-2017, 06:43 AM   #37
Chuck W.'s Avatar
Originally Posted by HJ47 View Post
Hello,
Thank you !
Sorry... No one can help you. As mentioned in this thread, the only way to determine which IMS you have is to drop the transmission and look at the cover.
If this is an issue now to you don't buy the car. If you do, it will haunt you. Or, if you do buy it plan on spending another $2,500ish to have it updated with one of the after market units out there.
There are many of us that just don't care. I may have mine replaced when I do the clutch.
My hat is off to you... you obviously used the search feature to find this older post. Keep looking and reading and you should be thoroughly confused when finished.
Good luck.
1995 Porsche C4 Cab
Old 07-23-2017, 08:46 AM   #38
Factor in the price of a quality IMS replacement and bargain for half the cost. If it is going to worry you, walk away.
Old 09-01-2017, 11:40 AM   #39
Originally Posted by Nimbus117 View Post
Porsche released the list of affected VIN's so check against this also:
6. Which Porsche vehicles are included?
The following Porsche Boxster and 911 vehicles that experienced or will experience IMS related engine damage are included:
• Model year 2001 - 2005 Porsche Boxster vehicles manufactured with an IMS between May 4, 2001 and February 21, 2005 with VINs in the following ranges:
o WP0CA29851S620508 - WP0CA29831S620619
o WP0CB29811S660405 - WP0CB29801S660492
o WP0CA29821U625959 - WP0CA29891U627644
o WP0CB29861U664289 - WP0CB29841U665473
o WP0CA29892S620061 - WP0CA29802S620238
o WP0CA29832U620061 - WP0CA29892U626107
o WP0CB29862S660062 - WP0CB29852S660344
o WP0ZZZ98Z2U602762
o WP0ZZZ98Z2U640813
o WP0CA298X3S620068 - WP0CA29853S620222
o WP0CA29813U620061 - WP0CA298X3U625002
o WP0CB29803U660063 - WP0CB29803U663240
o WP0CB29853S660068 - WP0CB298X3S660227
o WP0ZZZ98Z3U604185
o WP0ZZZ98Z3U640971
o WP0CA29854S620061 - WP0CA29824S621085
o WP0CA298X4U620061 - WP0CA29854U621568
o WP0CB29804S660061 - WP0CB29834S660555
o WP0CA298X5U710067 - WP0CA29815U711852
My VIN. number on my 03 Boxster is WP0CA29863U620735. Can some confrim for me my car is not affected by the IMS problem?
<<< Never mind looks like i jumped the gun i'm affected by IMS issue WP0CA29821U625959 - WP0CA29891U627644
JOC IN IL is offline   Reply With Quote
Old 09-01-2017, 12:09 PM   #40
In order of importance:
#1 Porsche never associated VIN numbers with engine numbers, so VIN numbers are useless in determining which style IMS is in a car, period. Assuming the car has its original engine, 1997 thru 1999 cars were all dual rows; 2000 and 2001 cars can go either way, but under NO circumstances will the VIN or build date tell you anything useful, you need to pull the car apart and look to find out if it is a single of dual row. THERE IS NO OTHER PROVEN WAY. Cars built from 2002 thru 2004 are ALL single row engines. 2005 is another crap shoot year, some of the cars are single row serviceable IMS bearings, others are the over sized non serviceable IMS bearing. Again, YOU HAVE TO PULL THE CAR APART TO FIND OUT WHICH ONE IT IS. VIN numbers, build dates, or phases of the moon won't help you, it has to come apart, period. 2006 thru 2008 engines are all non serviceable IMS bearings.
#2 Your 2003 car, if it has its original engine, has the single row bearing in it, which has the highest probability of failure (around 8-10%).
#3 All engines with IMS bearings in them have some level of potential for the bearing to fail, the only thing that changes is the probability of failure.
