Old 03-11-2013, 11:44 AM   #1
Alternative to Cycle Lever
I just finished dropping an Atlas lift into a recess in my garage floor. I am going to mount the pump / fluid reservoir on my front garage wall. As it comes from the factory, you must disengage a safety block to lower the lift by pulling on a cheesy bicycle brake lever. You can see it in action at the 53 second mark of this video:
Atlas TD6MR 6,000 LB. Capacity Portable Mid Rise Scissor Lift - YouTube
My question; I will still be using a bicycle brake cable to disengage the block but I wanted to utilize something more substantial / better than the incredibly crappy lever that came with the unit. Thought about an E-Brake handle but really doubt that would fly, any other ideas on levers / methods to be used?
Old 03-11-2013, 02:21 PM   #2
1999 base
Meir's Avatar
i have the similar lift from HF. the lever works just fine. its not like you need to apply a lot of force to release the looking tab.
the way i use it is as follow.
i start the pump, and get the lift to the desired height, making sure i stop when i hear the tab clicks. i lower the lift until it stops (when it heats the locking tab).
to lower the lift, i will first lift it up couple of inches, press the release lever, and lower the lift.
if you will use an ebrake mechanism, you might forget it puled, and that is not safe in my book.
by the way awesome job on the pit. looks great.
Old 03-11-2013, 05:53 PM   #3
Perhaps a Campagnolo lever?
'99 black 986
Old 03-11-2013, 07:51 PM   #4
com3dorm3's Avatar
Campagnolo Super Record - Carbon 11S
You won't find a more ergonomic, smooth, and precise lever for your lift.
2000 Boxster S
com3dorm3 is offline   Reply With Quote
Old 03-11-2013, 11:43 PM   #5
Ummmmmm.....those are impressive bits, but the lift isn't quite that nice lol. Prices I found for such levers roughly equated to a third to a half of the cost of the entire lift.
Probably just upgrade to a higher quality lever of similar design as what it came with........
Old 03-12-2013, 04:15 AM   #6
Johnny Danger's Avatar
The Campy lever won't work any way. It's a "road" style lever that functions completely different from that of a MTN style one.
