Old 02-23-2013, 05:14 PM   #1
Latest rev of coolant cap?
Gents,
What's the latest revision/part number for the coolant cap? I currently have 996.106.447.02. I have some condensate which I believe is coolant after each drive (no coolant tank leak which I've confirmed today). Thinking it might be the cap not sealing properly. Want to replace with latest version to rule it out.
Thanks.
stateofidleness is offline   Reply With Quote
Old 02-23-2013, 05:25 PM   #2
Spinnaker's Avatar
996-106-447-04
Old 02-23-2013, 07:21 PM   #3
Yes, -04. I just bought one from the dealer.
Old 02-23-2013, 07:27 PM   #4
oc-boxster's Avatar
Is it blue or black ?
oc-boxster is offline   Reply With Quote
Old 02-25-2013, 08:42 AM   #5
Hi slight hijacking, is the condensation not normal in the coolant cap trunk cover area? Mine has this also but the coolant doesnt have a significant loss in its level. The local mechanic says its normal because heat and cold is present in this are thus condenstaion. Which i find weird.
Pedrof is offline   Reply With Quote
Old 02-25-2013, 02:34 PM   #6
My understanding and experience is that it is not normal but not something to worry alot about. In my case I was getting some condensation on a fairly regular basis and replaced the coolant cap twice. In retrospect all of the coolant caps were fine so long as a good seal was established (clean gasket installed with a little water to make a tight seal). My coolant tank was also not cracked or leaking anywhere either. What was leaking vapor were the o-rings on the bleeder valve, and I understand that other parts of the bleeder valve can result in similar vapor leaks. Here is a recent thread I updated about this.
http://986forum.com/forums/general-discussions/37561-bleeder-valve-o-rings-whole-assembly.html
In my case I had too had no noticeable loss of coolant over many months.
Inspecting the bleeder valve is worthwhile but be careful as it is quite easy to strip or break the screws as well as other parts of it. No issue to just leave alone so long as you are convinced the tank is sound.
teleski is offline   Reply With Quote
Old 02-25-2013, 08:55 AM   #7
EssexPorsche's Avatar
04 - Blue. I still get a small amount of localised condensation on the underside of the trunk lid. Its currently just above freezing in the UK and a spirited drive results in condensation. I was checking everyday for fluid loss. But the level never moved so now i just ignore it.
Don't care......was made to care! (my Mum)
EssexPorsche is offline   Reply With Quote
