Old 11-24-2005, 10:28 AM   #1
Send a message via AIM to blinkwatt
Quick oil change question.
Im looking to change my oil shortly. I have the oil filter and o ring for the filter. Does the drain plug crush ring need to be changed? If so does anyone on this board have a extra one they would sell?
-99' Zenith Blue 5-spd...didn't agree with a center divider on the freeway
-01' S Orient Red Metallic 6-spd...money pit...sold to buy a house
blinkwatt is offline   Reply With Quote
Old 11-24-2005, 11:46 AM   #2
new crush washer
FWIW... I've used new washers only if they were supplied with the filter. Most of the time I've reused the washers. However, I paint a thin layer of fingernail polish (the wife's old stuff) on the drain plug's threads as a sealent. Just tighten the plug to the proper torque - no drips, no weeps. It is not that I am cheap; it is just convenient.
Dan, 2002 C2 Black/Tan
cyclocross is offline   Reply With Quote
Old 11-24-2005, 02:24 PM   #3
donv's Avatar
The crush washer is readily available at the dealer, if I remember correctly something like $0.50 to $1. When I bought with the oil filters on-line it was ~$0.25.
2001 Lapis/Black/Black, PSM, Rear Speaker Kit, Optima...
donv is offline   Reply With Quote
Old 11-24-2005, 03:01 PM   #4
Originally Posted by cyclocross
...However, I paint a thin layer of fingernail polish (the wife's old stuff) on the drain plug's threads as a sealent....
What's the best color?
Zib
Biz-z Z is offline   Reply With Quote
Old 11-25-2005, 07:31 AM   #5
Wink
Whatever she no longer uses. Let's see... Base Coat, Platinum, Rosetta Rumba (those go on the drain plug so no one can see them), and Denim Chrome (which is also a good match for the blue on the license plates.
Old 11-25-2005, 12:44 PM   #6
I like the sound of "Rosetta Rumba". I'll see if I can pick some up for my wife. Maybe she won't like it and I'll get to use it !
Seriously, finger nails polish really works as a sealant?
Zib
Old 11-26-2005, 06:44 AM   #7
Definitely buy some for your wife - also some jewelry. Then she'll not be too unhappy when you buy some goodies for your "S".
I've used nail polish for about 20 years both as a sealent and as a "LokTite". Just remember to insert the drain plug while the polish is still wet.
Old 11-28-2005, 08:49 AM   #8
deliriousga's Avatar
Replace it. The old one has conformed to the bolt wherever it stopped and the pan. That makes knicks and cuts in the aluminum crush washer and bends it to fit snug against the pan. If you use the old one, the knicks, cuts and bends don't match up and can allow leaks. It's cheap $.50 insurance against oil leaks.
1966 Wife White/Brown Top
