Old 02-19-2013, 12:51 PM   #21
Spinnaker's Avatar
Originally Posted by More View Post
Is it a hard job to fix if I was to do it on my own?
The hardest part will be jacking up the car and putting it on stands.
Old 02-21-2013, 07:34 PM   #22
More's Avatar
Originally Posted by Heiko View Post
There should be two... Looks like the remains of one of the two air guides that vent air upwards.... If they are gone I would highly recommend replacing them.
What could happen if I don't for questions sake?
1998 Porsche Boxster 986 Convertible.
More is offline   Reply With Quote
Old 02-21-2013, 09:53 PM   #23
Spinnaker's Avatar
If there wasn't a good reason for putting them there, they wouldn't have put them there in the first place. No company is going to go to the expense of engineering and designing a part, manufacturing the part, adding the part to the assembly process, and then expending the labor to install that part, if it isn't needed. Everything costs money, and if they can eliminate something, they would have to save the cost. It is the economics of manufacturing, keep the cost down to maximize profits.
My guess would be that it directs cooling air into an area that needs it. There is not a lot of air circulation in the engine area, since it is a mid engine design and the radiators are in the front. Unlike a front engine car that gets cool air rammed directly into it at all times. The exhaust manifolds and catalytic converters are in this area and are high temperature emitters. The engine compartment is very crowded in the Boxster and everything will get hot back there. The rubber spoiler scoops may help keep the temperatures in this area manageable. Higher temperatures generally mean lower component life, whether it is mechanical or electrical in nature. There may be a safety issue, elevated temperatures can be a fire hazard. Ever notice how hot the trunk is after a long drive? If I pickup a pizza to take home, I always put it back there it keep it hot. I remember reading a forum post about someone putting their shoes back there and the rubber melted.
Some of you engineers can chime in if my guess is off base.
Old 02-21-2013, 10:16 PM   #24
More's Avatar
That might explain the sickening grinding noise coming from the back of my car today.
Old 02-21-2013, 10:26 PM   #25
Spinnaker's Avatar
It's just the IMS bearing, ignore it.
Old 02-21-2013, 10:43 PM   #26
More's Avatar
What do you mean it's the IMS Bearing
