Old 02-06-2013, 05:29 PM   #1
slogans7's Avatar
Rear trunk won't stay open
I've seen lots of problems with lids that won't open when the battery's dead, but none about a trunk lid that won't stay open. And that's my problem. The trunk opens fine, but as soon as I put something in the boot, the lid falls on my head immediately.
Ow.
I don't know if the Stabilus gas springs are just shot and need to be replaced, or if they can be adjusted. I tried their site and found no help at all.
You guys know?
PS - Same problem on the hood of my wife's Merc E320 wagon. Is this contagious among cars?
2002 Triple-Black Boxster S
slogans7 is offline   Reply With Quote
Old 02-06-2013, 05:35 PM   #2
1999 base
Meir's Avatar
Ow.
You guys know?
Replace them. They are not adjasteble.
I replaced the rears as soon as I bought the car, and the fronts a year later.
Old 02-06-2013, 08:10 PM   #3
com3dorm3's Avatar
Did it happen to be very cold? On freezing days the shocks on my car can't hold the weight of the lid.
2000 Boxster S
com3dorm3 is offline   Reply With Quote
Old 02-06-2013, 09:08 PM   #4
Theoretical propagandist
Eric G's Avatar
Found mine in stock at Autozone. Just take one in with you match it up and your good to go.
Old 02-06-2013, 10:24 PM   #5
Gforrest2's Avatar
Yup, cheap and easy fix. I think I got mine off ebay for around $15.
Glen
Old 02-07-2013, 10:55 AM   #6
slogans7's Avatar
No, it clunks me in the head in all temps.
I was trying to find the exact model online, but Stabilus makes a lot of different lengths and types of this thing. Do you guys know the model number? Otherwise, the Autozone purchase sounds good.
Thanks for your help.
PS - is it pretty easy to swap out?
Old 02-07-2013, 11:33 AM   #7
CoBeerToad's Avatar
Pelican Parts - Automotive Parts and Accessories - Porsche & BMW
Maybe this helps?
CoBeerToad is offline   Reply With Quote
Old 02-07-2013, 12:35 PM   #8
Mine also closes (2007). Probably the springs need to be replaced. Note: Make sure you don't lay your keys in the trunk as you are putting other things in there. Then you may have another problem besides the lid hitting you in the head.
Soetekouw is offline   Reply With Quote
Old 02-07-2013, 02:09 PM   #9
I use a paint stick from Home Depot to hold mine open...works just fine. Some day I will replace pistons....
1998 986 with ladder racks.
paintboy is offline   Reply With Quote
Old 02-08-2013, 06:37 AM   #10
slogans7's Avatar
Originally Posted by CoBeerToad View Post
That's great, thanks.
Old 02-08-2013, 08:29 AM   #11
Rock auto has then very cheap....they work great. Don't get bonked in the head again. This is a 5 to 10 minute job.
Old 02-08-2013, 04:46 PM   #12
doragman's Avatar
agree..... rock auto --$20 and 10 minutes
'99 986 Baton Rouge, LA
doragman is offline   Reply With Quote
Old 02-12-2013, 10:39 AM   #13
slogans7's Avatar
Well I got the replacements but am baffled how to get the old ones out. Since I can't see the nut that apparently is holding them to the assembly, do I need to remove the whole assembly (don't know what else to call it - the black pieces attached to the car fram and trunk lid) to get the old ones off and the new ones on?
Also, are metric tools needed?
Last edited by slogans7; 02-12-2013 at 10:40 AM. Reason: photo appears in wrong place
Old 02-12-2013, 10:42 AM   #14
1999 base
Meir's Avatar
use a flat screwdriver to pull away the black metal tab.
the new ones will just snap in place.
Old 02-12-2013, 11:42 AM   #15
slogans7's Avatar
Thanks! I'll work on it tonight and say goodbye to the lumps on my noggin.
Old 02-12-2013, 11:51 AM   #16
1999 base
Meir's Avatar
helpful link:
Pelican Technical Article: Boxster Hood Shock Replacement - 986 / 987
good luck.
Old 02-13-2013, 07:38 AM   #17
slogans7's Avatar
Perfect, thanks again.
Tags
rear trunk lid , trunk
