02-06-2013, 05:29 PM
Rear trunk won't stay open
I've seen lots of problems with lids that won't open when the battery's dead, but none about a trunk lid that won't stay open. And that's my problem. The trunk opens fine, but as soon as I put something in the boot, the lid falls on my head immediately.
Ow.
I don't know if the Stabilus gas springs are just shot and need to be replaced, or if they can be adjusted. I tried their site and found no help at all.
You guys know?
PS - Same problem on the hood of my wife's Merc E320 wagon. Is this contagious among cars?
2002 Triple-Black Boxster S
02-06-2013, 05:35 PM
1999 base
Ow.
You guys know?
Replace them. They are not adjasteble.
I replaced the rears as soon as I bought the car, and the fronts a year later.
02-06-2013, 08:10 PM
Did it happen to be very cold? On freezing days the shocks on my car can't hold the weight of the lid.
2000 Boxster S
02-06-2013, 09:08 PM
Theoretical propagandist
Found mine in stock at Autozone. Just take one in with you match it up and your good to go.
02-06-2013, 10:24 PM
Yup, cheap and easy fix. I think I got mine off ebay for around $15.
Glen
02-07-2013, 10:55 AM
No, it clunks me in the head in all temps.
I was trying to find the exact model online, but Stabilus makes a lot of different lengths and types of this thing. Do you guys know the model number? Otherwise, the Autozone purchase sounds good.
Thanks for your help.
PS - is it pretty easy to swap out?
02-07-2013, 11:33 AM
02-07-2013, 12:35 PM
Mine also closes (2007). Probably the springs need to be replaced. Note: Make sure you don't lay your keys in the trunk as you are putting other things in there. Then you may have another problem besides the lid hitting you in the head.
02-07-2013, 02:09 PM
I use a paint stick from Home Depot to hold mine open...works just fine. Some day I will replace pistons....
1998 986 with ladder racks.
02-08-2013, 06:37 AM
Originally Posted by CoBeerToad
That's great, thanks.
02-08-2013, 08:29 AM
Rock auto has then very cheap....they work great. Don't get bonked in the head again. This is a 5 to 10 minute job.
02-08-2013, 04:46 PM
agree..... rock auto --$20 and 10 minutes
'99 986 Baton Rouge, LA
02-12-2013, 10:39 AM
Well I got the replacements but am baffled how to get the old ones out. Since I can't see the nut that apparently is holding them to the assembly, do I need to remove the whole assembly (don't know what else to call it - the black pieces attached to the car fram and trunk lid) to get the old ones off and the new ones on?
Also, are metric tools needed?
Reason: photo appears in wrong place
02-12-2013, 10:42 AM
1999 base
use a flat screwdriver to pull away the black metal tab.
the new ones will just snap in place.
02-12-2013, 11:42 AM
Thanks! I'll work on it tonight and say goodbye to the lumps on my noggin.
02-12-2013, 11:51 AM
1999 base
02-13-2013, 07:38 AM
Perfect, thanks again.
