Old 02-01-2013, 01:47 PM   #1
What size Torx bit
for the brake caliper bolts?
I am getting ready to do a brake job and found that my torx bits only go up to size T50 - too small. Will probably need T55, T60, or T70. I am guessing T60. Does anyone know for sure? Thanks.
Soetekouw is offline   Reply With Quote
Old 02-01-2013, 01:48 PM   #2
Should be T55
Bryan topping is offline   Reply With Quote
Old 02-01-2013, 02:03 PM   #3
I believe that the caliper bolts are a hex head bolt, not a Torx.
Old 02-01-2013, 02:11 PM   #4
Good point. The new bolts I ordered from SunCoast are torx. I need to check the brake caliper on the car (2007 Boxster S) to see if they are torx or hex.
Old 02-01-2013, 02:55 PM   #5
My 2001 base had 10mm hex (allen style). The replacements are now T55
Old 02-01-2013, 03:39 PM   #6
BYprodriver's Avatar
Internal or external Torx ? Hopefully external & if so sometimes a 6 point socket works.
Old 02-01-2013, 04:48 PM   #7
It's internal, T55 not E55
