Old 01-21-2013, 09:50 AM   #21
BYprodriver's Avatar
Originally Posted by rondocap View Post
OK, so I got a flat and had some issue with the Porsche tools. The jack I more or less figured out, but how exactly do you take the lug bolts out?
There seems to be 2 pieces in the tools, one that connects to the lug, and a handle that goes through it. Is that it? I used a lot of force and I could not get the lug nuts to budge, but it was much easier with a regular lug wrench.
Did I do something wrong or are those Porsche tools just kind of a bad and inferior to the lug wrench?
Like the rest of the car they are designed to be as light as possible & still perform the job they were designed for. Most likely the lugs were overtightened or corrosion has set in. I put a light coating of Anti-sieze on CLEAN lug threads to lubricate & reduce friction. This lubrication reduces the amount of torque needed to fasten & unfasten the lugs. I torque the lugs to 88 ft/lbs. This preparation makes the oem tools a joy to use & helps prevent corrosion later.
Old 01-21-2013, 04:26 PM   #22
Jager's Avatar
Originally Posted by Botoxster View Post
This is a blatant lie.
Nowhere Oklahoma has pothole ridden asphalt roads, and no discernible shoulder to change a flat tire on.
You must have been in the big city.
I was about 200 miles from Oklahoma City:
Jäger
300K Mile Club
Old 01-21-2013, 05:17 PM   #23
SPB racer
Isn't the socket 19mm? I think mine are.
Absolutely correct. 18" bar / 19mm deep socket.
Jittsl is offline   Reply With Quote
Old 01-29-2013, 10:25 PM   #24
Just another question: I'm going to do my brakes, should I put the car in 1st gear, reverse, or neutral when I have it jacked up?
I plan to use jack stands. Do you have to put them on both l/r sides when working on just one side?
rondocap is offline   Reply With Quote
Old 01-30-2013, 08:21 AM   #25
So it's safe to say...you were in the middle of Nowhere?
