Old 01-03-2013, 03:55 PM   #1
What I am doing wrong for smooth shifts?
This is my first manual car, so It's a learning process.
I noticed that went I shift from 1st to 2nd, to 3rd, at around 2k RPM, the shift is pretty smooth and I apply smooth gas as well minimally.
When I shift from 1st to 2nd at a higher rpm, like 3 or 4k, I get a bit more of the car engaging not smoothly. Is this because I have to give more gas to match the rpms when it is 3k +? I'd guess that around 2k I need to give it less gas as I disengage the clutch.
Also, is it normal for there to be slightly more resistance on the shift from 1st to 2nd as opposed to 2nd to 3rd?
rondocap is offline   Reply With Quote
