Old 12-22-2012, 05:14 PM   #1
The Legend
boxslrr's Avatar
Engine Grinding/Clicking Noise -- IMSB? (VIDEO)
Hi all. This 98 Base 2.5L is making a grinding/clicking noise. I'm fairly sure the IMSB is going bad and needs to be replaced. Thankfully the engine has not blown and the car ran right before we started to work on it. Could this noise be from the IMSB? Or possibly some secondary problem resulting from the IMSB such as the chain tensioners?
Video
986 Boxster -- Engine Grinding - YouTube
boxslrr is offline   Reply With Quote
Old 12-22-2012, 05:25 PM   #2
I am not expert enough to say what might be causing this (several things come to mind but I won't speculate), but that noise is not normal. I'd shut it down and have it trailered to a shop for a professional opinion. At this point, you want to avoid a catastrophic failure that could damage a lot of engine components.
Old 12-22-2012, 06:57 PM   #3
dan.oneufer's Avatar
Seems risky to run it, even to provide an audio sample to us. If there is an internal part causing the noise and it hasn't fractured it may be repairable.
I would have a good indy take a look.
2003 Boxster S Dark Teal
dan.oneufer is offline   Reply With Quote
Old 12-22-2012, 07:30 PM   #4
thom4782's Avatar
+1 on don't run the engine. Tow it to a shop and play the video for them before they crank it.
Old 12-22-2012, 08:35 PM   #5
Newb
V-Rod's Avatar
Just curious. How many miles on this '98?
1999 Boxster Ocean Blue Metallic/Savannah Beige
2001 Harley Davidson Road King w/Ultra Kit Black/Chrome
2004 Jaguar XJ8 Seafrost Metallic Green/Sand
2008 Land Rover LR3 Alaska White/Alpaca
2012 Honda Odyssey Touring Dk Grey/Lt Grey
V-Rod is offline   Reply With Quote
Old 12-22-2012, 10:09 PM   #6
Skrapmot's Avatar
Sounds to me very much like a timing chain slipping rather a mechanical death rattle.
With me, it still would be to much time consuming work to fix this time of the year ,so i would tow it to a garage.
Old 12-23-2012, 05:04 AM   #7
Sounds like lifters/valves almost...no matter what that's a bad noise!
1999 986 2.5L, Stock Exhaust (S muffler), EVO Intake, 18" Stock rims (17" during winter), IMS Upgrade, 150k+ miles and counting!
87 944S brought back to life
Dragonwind is offline   Reply With Quote
Old 12-23-2012, 06:10 AM   #8
Could be the starter motor sticking. That would certainly be nice!
pothole is offline   Reply With Quote
Old 12-23-2012, 06:26 AM   #9
Agree,it sounds like a valve. The safest thing to do is have it flat bedded to a mechanic but if it were me, I would look at the oil filter to see if there is any metal in it. If the filter is clean, then I would check the timing with the Durametric. If the timing is good, I would get under the car while its running and use a stethoscope to try to pinpoint where the sound is coming from.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
