Old 12-21-2012, 09:28 PM   #1
Is it just me, or is the 986 Boxster noisy and rattle prone?
I've driven a few different Boxsters, 986, including the one I bought.
I noticed that with the roof up, they are all fairly noisy. You still hear some good road noise, and there is a lot of chatter within the car itself - some rattles come from the front dash, some rattles from the top area, etc.
Is this common on Boxsters, or is mine particularly noisy?
rondocap is offline   Reply With Quote
Old 12-21-2012, 09:37 PM   #2
Multi-Boxer Driver
Deserion's Avatar
Might be yours, but mine rattles a little too. Mainly when going over harsh bumps it rattles behind the driver's seat in the roof stowage area. And sometimes the center wind deflector. That's really about it.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
Old 12-21-2012, 09:53 PM   #3
All of the Boxsters that I've driven or rode in are somewhat noisy and have a few rattles. My solution is to put the top down and keep the rev's up!
Old 12-22-2012, 12:03 AM   #4
Nimbus117's Avatar
Mines a 2003 model and was impressed with how quiet & how few rattles there were for a convertible. The hardtop rattled and squeaked a bit but that I found was due to the plastic caps were missing off the lugs that slide into the top of the windscreen.
All my rattles came from the exhaust, lambda probes kept coming undone, heat shield rattles and a missing clamp. Still not entirely sorted but a lot better than when I got it.
Old 12-22-2012, 03:31 AM   #5
I think they all rattle a bit.
Actually, I had a new gen 2 Cayman 2.9 for a week. That rattled a bit too. Unfortunately, the build on all these cars is a bit flimsy. Keeps the weight down, but tends towards rattles.
Just compare how light the doors are on a 986 to an old 911 or a 968.
Old 12-22-2012, 05:00 AM   #6
Vista glass
Vista glass's Avatar
Yes I have rattles also. especially with the top up. fortunately this is a rare circumstance. I secured the mesh inserts, center screen and visor mirror flaps better than OEM to eliminate a lot of noises. Normally the top down,and the wind rushing by mask any other rattles
Vista glass is offline   Reply With Quote
Old 12-22-2012, 05:31 AM   #7
top down = no rattles
much quieter with the hardtop too.
ragtops rattle. it is what it is.
fatmike is offline   Reply With Quote
Old 12-22-2012, 05:32 AM   #8
Autobahn Glanz
WhipE350's Avatar
Yup they are noisy especial when the weather is colder. Not a first time date car with the top up.
I have both a 2000 'S' and a 2007 Base and there is a big difference with the tops up. The only common noise they have is the whine of the engine.
The joints in the top you can dry lube and of course it's easy enough to get rid of the wind screen rattles. I'm going to be taking some thin carpet pad and putting in the roof and see if helps (and make sure it doesn't mess with the operation of the top). I also considered insulating the cover over the engine behind the seat. I like exhaust and air intake sound but the whining of the engine right behind gets to be a bit much. This of course is just experimental since I little fiddling with the car anyway.
With the top down (especially in cooler weather again) the wind noise is much worse in the 986 but that's quite alright since I love the open air.
I find with the 986 just put the top down and rev it up...I'm a top down guy, it just feels like a totally different car. There are not rattles to distract from the great handling and performance.
Old 12-22-2012, 08:35 AM   #9
recycledsixtie
recycledsixtie's Avatar
I have the top up most of the time and I find that it is one of the most rattle free convertibles I have ever had. In the colder weather here the suspension is firmer and I tend to hear more rattles. But it is not bad enough to justify a hardtop.
Old 12-22-2012, 09:02 AM   #10
After +50,000 miles in 7 driving seasons with the 2006 987S I am VERY impressed with how rock solid the interior has been, with regards to rattles and such.
Old 12-22-2012, 09:10 AM   #11
Either I'm deaf or lucky because my 2001S has remarkably few noises for a convertible sports car of its age. About every 6-9 mos I hit the rubber cabin seals with Gummi-Phlege and it is as quiet as a church in there. I do get a little chatter only over steep-edged bumps due to deterioration of the bushings in the rear trailing arms, just waiting for my annoyance to exceed the cost of replacement. Sorry you guys are having so much trouble. Wonder if I would have more rattles had I gone ahead with an aftermarket exhaust?
Old 12-22-2012, 09:11 AM   #12
walt2810's Avatar
I have a My99 with 52k and after 13 years There are some rattles especially top up. Not as much when the top is dropped. For a soft top convertible I guess it comes with the territory. A family member just got a 05 987 and did not hear any rattles while test driving that. Newer, insulated roof, So hope that won't rattle as much as it gets older.
walt2810 is offline   Reply With Quote
Old 12-22-2012, 12:09 PM   #13
Moderator
The interior seems pretty solid, it's mainly the worn bushings in the suspension that gives the car it's squeaks and rattles when going over bumps I'd say.
Old 12-22-2012, 12:49 PM   #14
Guys could always try a front strut bace to tighten up stuff in the front and windshield area. Cheap and easy to do. I've used one since very early in my ownership experience. Even get real nice turn-in as a caveat.
Old 12-22-2012, 10:28 PM   #15
Cool. Never heard of Gummi-Phlege before. Sounds like what I need to deal with my squeeking window seals when the car flexes on bumps. Just placed a quick Amazon order to try it out! Thanks BrokenLinkage for the mention.
teleski is offline   Reply With Quote
Old 12-22-2012, 11:08 PM   #16
No rattles here. Hardly even if any wind noise with the top up.
Old 12-22-2012, 11:44 PM   #17
Idaho Red Rocket 3's Avatar
2K S with 76K miles. Too quiet inside with top up windows closed. No rattles.
2000 Boxster S
Old 12-23-2012, 05:36 AM   #18
dan.oneufer's Avatar
I'm surprised just how noise free my 03 is. Having owned convertibles in the past (MGs & Triumphs), I feel the level of wind/road noise is far less in the Boxster than in the others. As far as mechanical noise, my Saab and Infiniti (neither were convertibles) had way more squeaks and creaks.
It seems nice and tight.
2003 Boxster S Dark Teal
dan.oneufer is offline   Reply With Quote
Old 12-23-2012, 09:38 AM   #19
My 2000 is surprisingly quiet. With the top up I have essentailly no rattles, can't really hear any major road or tire noise over the sound of the engine. Going over big bumps, I get just the slightest cowl shake but no rattles or noises.
The only time I hear noise is when a big 18 wheeler is right next to me then I can hear noise through the top canvas.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 12-23-2012, 03:24 PM   #20
BYprodriver's Avatar
I agree with this, + when the engine mount bushing wears lots of things get noisy!
