Old 10-31-2005, 07:40 AM   #1
Cool The dreaded "Check Engine" light
I drove up the PCH this weekend starting from La Crescenta. Before starting, I decided it would be a good time to add a bottle of Techron.
I put 1 bottle to 12 gals of gas, as recommended.
After nearly depleteing the tank, I stopped and filled up. After one of our stops at a winery, the "Check Engine" light came on. I am not sure whether the above had anything to do with this, but its the only thing I've done recently.
Question: Is there anyway of accessing the problem code # and then get identifying it.
mccarrm is offline   Reply With Quote
Old 10-31-2005, 08:21 AM   #2
bmussatti
Guest
Posts: n/a
mccarrm, check to make sure your gas cap is properly tightened.
Old 10-31-2005, 09:30 AM   #3
Thanks!
I did, and even after 100 miles it still remains ON.
A little more information:
It's a '98 with 50k miles.
The only upgrade is a cold air intake filter, which was installed about 500 miles ago.
I called Autozone, in the area, and they will let me use their reader (with a $170 deposit).
Once I get the number, I am sure I will have more information.
Thanks again,
Mike
Old 10-31-2005, 09:47 AM   #4
bmussatti
Guest
Posts: n/a
mccarrm, yes the code(s) will be very beneficial. You can also check-out the PCA web-site's Tech Section, there are a lot of threads there for the CEL. They reference a lot of the code #'s too.
Old 10-31-2005, 12:21 PM   #5
That CEL can be a bunch of things... so a code reader will certainly help and it's not worth speculating on what it might be.
I tell you what though... the boxster's brain does NOT like intake mods (different filters, modified airboxes, cone filters, etc.) from all I read on this forum as well as renntech.
One thing you might try is disconnecting your battery for a half hour or so and see if the CEL light goes off. Some folks say this works.
Old 10-31-2005, 01:28 PM   #6
Does your cold air intake include an oiled filter (like a k&n)? These oiled filters seem to always screw up the MAF. Pull the codes and you'll be on your way to a fix!
2000 Porsche Boxster S
2007 Lexus RX350
xclusivecar is offline   Reply With Quote
Old 10-31-2005, 04:18 PM   #7
Jeph's Predictions
If it the CEL doesn't go away after the next day or 2 by itself, I predect the 02 sensor in bank 1.
There's no logic behind this speculation... I'm just writing this because I'm bored. Let me know if I'm right.
1997 Honda Accord | V6
2004 BMW 330i | ZHP | SOLD
2000 Porsche Boxster | SOLD | http://www.986forum.com/forums/showthread.php?t=9114
http://www.kryzak.com/storage/986sig12.jpg
http://kryzak.tumblr.com
Jeph is offline   Reply With Quote
Old 10-31-2005, 04:47 PM   #8
If the CEL came on after filling the tank check to be sure the gas cap is replaced correctly. There is a switch that will trigger the CEL if something impedes the cap from going on perfectly.
Paul B is offline   Reply With Quote
Old 10-31-2005, 05:38 PM   #9
Brucelee's Avatar
These gas caps also go bad, more frequently than you would believe.
Try replacing it. Cheap.
Old 10-31-2005, 09:52 PM   #10
Send a message via AIM to bhduxbury
i was just at the intersection of honolulu and la crescenta today filling up at my nearest chevron station (i live in glendale just below montrose) -- so, howdy neighbor! and, importantly, good luck with the CEL -- hope it's no biggy!
bhduxbury is offline   Reply With Quote
Old 11-03-2005, 04:53 PM   #11
bmussatti
Guest
Posts: n/a
mccarrm, did you get the codes pulled off yet?
