Old 10-17-2005, 10:16 PM   #1
5mm spacer option
The new porscheusa.com site for the Boxster and Cayman list 5mm spacers as optional equipment. (I didn't check the Carrera -- maybe there too.) Anyone know why?
SoCal is offline   Reply With Quote
Old 10-17-2005, 10:24 PM   #2
HI,
Wider Track, a little better sticking ability...
Happy Motoring!...Jim'99
Old 10-18-2005, 04:01 AM   #3
bmussatti
Posts: n/a
SoCal, I ordered my 987S with the 5 mm spacers. I did this more from a visual standpoint, and to make it a little more unique. FYI, the Anniversary 986 came from the factory with the 5 mm spacers standard.
Old 10-18-2005, 04:19 AM   #4
bmussatti
Posts: n/a
If anyone wants to know the numbers, they are:
Ordered with the car from the factory- Code# XRP $490 (includes the longer, anti-theft protection bolts too)
From Tequipment- Code # 000 044 500 09 (also includes the bolts). I don't know the costs.
Note, these can not be fitted on the Carrera Sport Wheel 19"
Old 10-18-2005, 05:03 PM   #5
Bmussati:
Do you know why the 5mm spacers are not for use on the sport design rims? Are they different offsets?
Chris
Chris C Atlanta is offline   Reply With Quote
Old 10-19-2005, 06:05 AM   #6
bmussatti
Posts: n/a
Chris C Atlanta, I don't know for sure the exact reason. I don't think it is related to the offset, though, because the offset is the same as the 19" Carrera Classic Wheel (57 front and 46 rear). My guess is that it has more to do with the style and design of the Sport Design Wheels, they are very "open" near the centers, and possibly the wheel spacer would be exposed behind the wheel. Just a guess!
Old 10-19-2005, 11:20 AM   #7
Are you referring to the Carrera S wheel or the Sport Design wheel?
Carl AMG is offline   Reply With Quote
Old 10-19-2005, 11:27 AM   #8
bmussatti
Posts: n/a
Carl AMG:
I am referring to the Tequipment Book.
They state that the 5 mm wheel spacers are not compatible with the Sport Design Wheel (987 044 602 03).
The Carrera S Wheel is 987 044 602 05 and apparently compatible with the spacers.
Old 10-19-2005, 12:17 PM   #9
deliriousga's Avatar
There are tons of aftermarket spacers available made of the same or better materials at a fraction of the cost. Do a net search and you'll find plenty. Just make sure you get the right length replacement lug bolts when you move the wheels out.
1966 Wife White/Brown Top
Old 10-19-2005, 12:20 PM   #10
bmussatti
Posts: n/a
...and make sure the longer lug bolts have an anti-theft mechanism!
Old 10-19-2005, 01:10 PM   #11
True that. Excellent point bmussatti. You can buy the four anti-theft lugs at a dealership using your lug key code and get the rest with the spacers.
Old 10-27-2005, 08:23 AM   #12
bmussatti
Posts: n/a
Question about wheel spacers:
Do they always stay attached to the car? What I mean is, when the wheel is removed (for any maintenance) does the spacer come off or stay attached?
Thanks.
Old 10-27-2005, 08:51 PM   #13
Originally Posted by deliriousga
There are tons of aftermarket spacers available made of the same or better materials at a fraction of the cost. .
Kinda like these? 1/4 inch= 5mm.
http://www.tweeks.com/shop?frame=8.2257
