Old 11-13-2012, 02:02 PM   #1
Weird starting problem
I've had problem with intermittent starting problems before, but not in quite a while. Suddenly now that it's cold out, my car is consistently hard to start. It doesn't crank at all. I try to start it a bunch if times and get nothing. Then all of a sudden it starts. All summer it was fine, but now that it's cold out I have trouble every time I try to start it.
Anybody have ant idea what could cause that? Btw, I replaced my ignition switch assembly last year.
Sent from my SPH-D710 using Tapatalk 2
Mike_Yi is offline   Reply With Quote
Old 11-13-2012, 02:13 PM   #2
MANual or tiptronic
Old 11-13-2012, 02:14 PM   #3
Dave S.'s Avatar
When my starter went out in another one of my cars it acted the same way. It had intermittent starting problems. It seemed very random at the time. Of course I'd suggest you check for good connections or corrosion at the battery and starter before anything else.
Dave S.
2003 Boxster S
Old 11-13-2012, 03:01 PM   #4
It is a manual.
Somebody I'm working with also just suggested to me that it could be slightly corroded battery terminals. That with the cold might rob the starter of enough power that it wouldn't turn over.
Old 11-13-2012, 03:05 PM   #5
Homeboy981
Homeboy981's Avatar
"Occam's razor" would seem to apply here. Check the battery terminals, connections….does horn work? Is it vivid or kinda flat pitched?
Old 11-13-2012, 03:06 PM   #6
Homeboy981
Homeboy981's Avatar
Oops! Sorry! @Mike_Yi, you are in Chicago….did you pay your dues?
Old 11-13-2012, 03:08 PM   #7
In that case, check clutch switch too. You can jump it if need be (and to test), just make sure clutch is in or transmission is out of gear when doing so
Otherwise, test battery and look for corroded terminals or check starter.
Good luck
Old 11-15-2012, 02:54 PM   #8
I cleaned battery terminals, but that didn't help. I think I'm going to try cleaning the connections at the starter (and not looking forward to that). I may take the battery in to get it checked too.
Old 03-30-2013, 02:06 PM   #9
Just wondering how horn not working would be related to start issue, because I am having start and horn issues intermittently
dennis is offline   Reply With Quote
Old 03-30-2013, 02:11 PM   #10
Jager's Avatar
Inspect your battery cables; we have seen other members of this forum experience corroded battery cables.
Jäger
300K Mile Club
Old 04-04-2013, 01:26 PM   #11
Topless's Avatar
Weak sounding horn = weak battery. Weak battery = no starty.
+1 on checking the clutch microswitch. Also the crank position sensor is known to cause similar symptoms... and a failed ign switch.
Old 04-04-2013, 10:25 AM   #12
Kiritsugu
Kiritsugu's Avatar
It's probably your clutch microswitch, I had the same problem over the winter. I had the starter and relay replaced, but it was still happening. Then I found a thread on Renntech, and they had the same problem. They fixed it by replacing their clutch microswitch and so did I.
"Drive it like you stole it..."
Kiritsugu is offline   Reply With Quote
Old 04-04-2013, 12:35 PM   #13
Mine did the same thing. Starting the car was like a spin of the roulette wheel - green was go and red was no-go. It was the clutch microswitch.
Old 04-05-2013, 03:52 AM   #14
smagerstein's Avatar
The same happened to me a couple years back. Clutch switch, fast cheap fix, even at the dealer. Perfect ever sinse (same battery for 7 years)
Steven Magerstein
2002 Boxster 2.7 Seal Grey
2008 MB C200k
Past Cars
2006 MB C180k
2005 Peugeot 306
1980 928
2004 Subaru Liberty GT
2000 Nissan Pulsar SSS
smagerstein is offline   Reply With Quote
Old 04-05-2013, 05:02 AM   #15
I am also experiencing the "lock" button light coming on and car locking while driving. Is this the immobilized?
Old 04-05-2013, 06:25 AM   #16
thom4782's Avatar
@ Dennis:
I had a symptom where the red lock light would come on while driving. In my case it was a defective passenger door latch. I noticed the link between the light and latch when I saw that operating the latch from outside would make the light come occasionally.
Old 04-05-2013, 07:43 AM   #17
Don't all of Porsche's little electrical gremlins make you feel confident about the long-term reliability of the electric emergency brake and power steering on the new Boxster? Just saying.....
Brad
southernstar is offline   Reply With Quote
