Old 11-13-2012, 06:44 AM   #1
jakesbox
trimer's Avatar
Oil Seepage
All
If you wanted to check the RMS for seepage, where would you look? Would you be under the car looking up? Looking down through the engine compartment? Looking at the engine from behind the seats?
Just curious.
Old 11-13-2012, 07:09 AM   #2
At the very bottom of the engine at the union of the engine and tranny. If its a stick, you will see the teeth of the flywheel through some slots in the case. thats where the union is.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 11-13-2012, 07:09 AM   #3
Moderator
In between the transmission and engine block, where they meet up.
Old 11-13-2012, 11:02 AM   #4
jcb986's Avatar
Oil leak at this point maybe more like the rear main seal. But if really want to check it you will need to pull the tranny first.:dance:
Old Hippie Young Heart
Old 11-13-2012, 11:18 AM   #5
Theoretical propagandist
Eric G's Avatar
jcb is correct as even if you could put a borescope into the bell housing, the flywheel and clutch block the direct view of both the IMS and RMS...and any oil you will see, you won't be able to differentiate which one its coming from.
Best of luck and if you do pull your tranny you might want to consider the following items to replace as this would be the only time (or easiest for access):
IMS, RMS, full clutch kit, dual mass flywheel, CV boots, coolant reservoir, AOS, water pump and thermostat; and check your coils, spark plug tubes and spark plugs.
I know it may seem a bit extreme, but if you are paying to have this taken off and checked, you will spend more in dollars down the road verses doing these now and having them off the "to do list".
