Old 11-12-2012, 11:06 AM   #1
Yellow plastic headlight clips
Greetings all,
The latest and greatest issue with my 02 S seems simple enough. but I wanted to check in here before doing something stupid. I pulled my driver's side headlight assembly to replace my L beam bulb last week. When I slid the light back in and turned the locking arm I heard a crack as the arm clicked into place. Turning the lights on confirmed what my ears had already told me; the bracket that holds the plug to the mounting plate had cracked. I pulled the light back out and found the plastic retainer for the plug had cracked and was no longer securing the plug.
I was able to pull the fender liner and attack it from the wheel well to hold the plug in place and got everything hooked back up, but I don't want to deal with this every time I need to change a light bulb.
Is there a source for the plastic clip that holds the plug to the mounting plate, or do I need to drop $100 to get $2 part????
Thanks!
Ross
shadrach74 is offline   Reply With Quote
Old 11-12-2012, 12:12 PM   #2
Take a look here to find exactly which part you need: Porsche Boxster Headlamp Parts
Old 11-12-2012, 02:04 PM   #3
Many thanks! It's item #12 "locking clip". It's only $6.37 for a $.05 piece of plastic! Much better than $98.00 for the assembly plate..
