Old 11-08-2012, 11:56 PM   #1
Confirm: Window Regulator Replacement and Airbag
Fellas,
Needing to do a Regulator swap tomorrow on my driver's side and wanted to confirm something with the airbag. I'm going to follow this guide: Boxster Projects | Power Window Motor Repair
If I disconnect the battery, is this enough to keep the airbag from accidentally deploying? Do I need to do anything special to not trigger an airbag light on the dash?
Thanks!
stateofidleness is offline   Reply With Quote
