Old 11-08-2012, 12:10 PM   #1
The later 6-speeds are also again a bit different. For one the slave cylinder cannot just be replaced with the transmission attached.
Swepco 201 is good for cars that get tracked but will be notchy. I was given a combination that so far shifts BEAUTIFULLY! Better than the stock fluid at 100K.
2005 987 - 112K miles PASM + 6-speed - Daily Driver
1988 944 - 240K miles- Race Car
1974 911 Targa - new project
2009 Triumph Street Triple R - 27K mi - Blazen Orange
1976 Ford F250 camper special - tow vehicle
944boy is offline   Reply With Quote
Old 11-11-2012, 05:22 PM   #2
barkinfool's Avatar
Sorry for the delay in getting back to you, I took a weekend trip & just got back.
Sean, changed it at 28,500 due to it being 11 years old vs symptoms or mileage. Used Porsche trans oil which was > $40 a liter so it is spendy, for 3L ~$130, but amortized over that much time not too big of a deal. Shifts well, not sure there is any difference from before the change, but I have more piece of mind.
Barkinfool
'02 Boxster S
barkinfool is offline   Reply With Quote
Old 11-11-2012, 05:56 PM   #3
Good call on the oil. Other are definitely problematic if you are in cold weather areas.
2012 Panamera 4
2010 Boxster
2000 Boxster S 3.2L
1990 Land Rover Defender 6x6
Old 11-11-2012, 06:26 PM   #4
still plays with cars...
BoxsterSteve's Avatar
Great post and just in time too. I'm doing this project while Udo is laid up for the winter as well as installing a GBox 2nd gear detent, oil change and a brake fluid flush. Service records I have don't show Brake fluid replacement, so I figure it's high time.
I'm only at 83,000 km, but trans oil is 12 years old and I need to undress the bottom of the car to swap the detent, so trans fluid's getting done "while I'm in there".
Nothing like bonding and busting knuckles while the ride's in storage.
BTW, I got the Porsche trans fluid for $28.90/liter and Super Blue for under $18/liter from Suncoast Porsche in FL. Bought from them before, great to deal with.
Six speed 2000 Boxster S
