Old 10-27-2012, 06:51 AM   #1
ChrisZang's Avatar
Ride height
Hi,
need a quick favor:
I have PSS9 and my car is riding too low.
I want to raise the ride height, which can easily be done with the PSS9
Could someone with a stock suspension and 18" wheels do me a favor and measure the distance from the wheel arch to the floor for front and rear (see attached picture what I mean).
For my adjustment I am shooting for the middle between stock and what I currently have. (and yes I will also do the alignment after that)
My current ride height is:
front 24 3/4
rear 24 7/8
Old 10-27-2012, 09:17 AM   #2
You may want to list tire sizes and current tire pressure to give yourself an accurate comparison
58ceramicgreen is offline   Reply With Quote
Old 10-27-2012, 09:32 AM   #3
ChrisZang's Avatar
225/40/18 32 psi front
265/35/18 34 psi rear
Old 10-27-2012, 10:41 AM   #4
with row m030 kit:
F = 26.0 inch
R = 26 3/8
brp987 is offline   Reply With Quote
Old 10-27-2012, 11:35 AM   #5
26 1/4 front
26 3/8 rear
Botoxster is offline   Reply With Quote
Old 10-27-2012, 06:23 PM   #6
ChrisZang's Avatar
Thanks guys
Old 10-27-2012, 07:03 PM   #7
Track rat
Topless's Avatar
FWIW
My suspension setup guys suggested that fender height is not a relevant measurement. Corner balance is what matters.
My fender heights w/full gas tank, no driver:
LF 24"
RF 23 31/32"
LR 24 7/8"
RR 24 1/2
It's pretty low in front.
Old 10-28-2012, 07:39 AM   #8
ChrisZang's Avatar
@ Topless:
100% agreed, the car is corner balanced, but simply too low for a daily driver.
So I just want to raise all 4 corners equally so I can clear the speedbumps at my work (currently I am bottoming out if I go faster that 5 mph).
Old 10-29-2012, 06:11 AM   #9
jaykay's Avatar
Chris can you traverse them on a diagonal and save your set up?
Try putting one front over at a time by zigging and zagging....this also prevent the chassis flopping down as front and rear axles go over
986 00S
Old 10-29-2012, 07:13 AM   #10
Johnny Danger's Avatar
Originally Posted by ChrisZang View Post
@ Topless:
You need to install "jump jacks" like the Mach 5 has .
Speed Racer - Mach 5's Advanced Features - YouTube
Old 10-29-2012, 04:27 PM   #11
My 2000 Box S with H & R red color springs and 18" wheels with 265-35-18 etc is TOO LOW and I'm removing and installing the original USA M030 springs that came on the car tomorrow.Camber is crazy too.The look is sweet but the ride is too rough and tires will not last like this.Current is as follows:
Drivers side
F24 1/4
R25
Pass side
F24 1/2
R24 7/8
litespeedp is offline   Reply With Quote
Old 10-30-2012, 05:37 AM   #12
ChrisZang's Avatar
Thanks for all the tips. I followed the instructions here Bilstein PSS9 - How to adjust ride height - 6speedonline.com Forums and increased the ride height by 2 cm = 3/4" all around. I might add another cm to it
so currently I am at
F 25 1/2
R 25 3/4
Old 10-31-2012, 04:35 PM   #13
Got my Box S back today after removal of H and R Red Springs and install of my original USA M030 and all settings back to stock.Springs will definitely settle out after I guess about 100 miles.Much better ride and no more dragging and the only loss of accuracy appears to be when pushing at about 85%. Added maybe 1 and 3/4 height.Like this a lot.P got it right with USA M 030 IMHO!
