Old 04-16-2014, 06:01 PM   #21
epapp's Avatar
Hi Bala,
Was this ever solved?
epapp is offline   Reply With Quote
Old 04-17-2014, 04:15 AM   #22
Benjamin's Avatar
Originally Posted by talvez View Post
Would a bad end float cause a leak to form behind the pulley?
I'm assuming you're getting an oil leak from there and that's why you are asking.
There is an oil seal there and excessive end float shouldn't cause it to leak, because "end float", as I define it, is excessive movement of the crank moving in and out, along the axis of the crank. The seal should continue to to work in this case. A bad bearing would lead to run out, in which the pulley end would move side to side. This could potentially lead to the seal leaking. Or the seal could just be old and tired and leaking or some debris from the inside has compromised it.
2000 986 S - "The Black Widow"
Benjamin is offline   Reply With Quote
