10-17-2012, 11:17 AM
#21
Looks like that filter could use a clean! Which sucks because it was bear to get that thing in there!!! lol
Can't see any part numbers!
10-17-2012, 11:26 AM
#22
Jaykay, the bolt in the top of the picture secures the box to the fire wall.
10-17-2012, 11:28 AM
#23
Dyno booked for tomorrow morning.
Hey I'm wiping down my engine now, feeling embarrassed !!!!
Can I put a hose pipe in there ? Never washed it before.
10-17-2012, 11:46 AM
#24
1999 base
yes you can wash it.
just don't use high pressure with the hose.
once you done, take her for a spin and get the engine to operating temperature.
that will dry her out. :dance:
10-17-2012, 12:25 PM
#25
Thanks.....I was talking about the other end of the box, inside of the engine bay near the MAF housing
986 00S
10-17-2012, 12:47 PM
#26
Clean again
10-17-2012, 01:04 PM
#27
1999 base
Clean again
man you are fast.
and that's while replying my emails
see you Sunday mate.
10-18-2012, 06:20 AM
#28
Homeboy981
Clean again
@blair,
Good job on the install. I am right there with ya. But have to ask….isn't the intake tube "collapsed" a little coming from the Throttle Body? It looks "flattened out" in the pic, is that right?
I also gleened some information, thanks @sparker, that may help with airflow over the MAF…that is using a "honeycomb" to straighten out the airflow. In most cars the intake does not twist and turn quite as much. This "honeycomb" filter is like a bunch of little straws that force turbulent air down the "straight and narrow". This results in more dense airflow throughout the width of the intake.
Here is a thread about how it works (it is for V-8 guys - so don't get your Box panties in a wad).
100mm Maf kickin my Butt!!! - HP Tuners Bulletin Board
Another member used this when increasing the size of the intake tubing to 4". Anyone else used this?
10-18-2012, 11:47 AM
#29
Blue line today
Red Baseline ?
10-18-2012, 11:48 AM
#30
I have a dyno from earlier @ 225. With age I can't quite remember the time line but I think 225 was with 91 octane fuel and 229 was with 93. Both with the chip from "Powerchip".
Never did a baseline before that, which was sad because I don't think the chip did much. Any how it did give me a base line for future mods.
Since last Dyno I did the following :
Pedro's engine mount (mine was toast)
BMC Air Fliter
Fabspeed Cat-Backs
Pedro's Throttle Body and Chip.
BBI under drive pulley
Giving me a gain of 11.7 hp at the wheels, about 14 hp at the crank.
Today in Atlanta it was 66 degrees and 93% humidity. I did the dyno last year around this time, but can't remember the weather. One more thing I just drove back from Texas and don't remember what Octane I used at every stop! I was at a 1/4 tank when I filled up at BP with 93 before dyno.
So did the original chip work ? Did I have some 91 octane in the tank ? 93% humidity ??? Weather last year ?
Lots of variables to say the least. I think I'll will go back after another tank of gas, on a 50% humidity day and cross out that those varibles, just for piece of mind. Either way I'm up to 284hp (15% loss = 241hp) and a nice flat power band. The Dyno guy was impressed, he had a 2001 S in 215 hp !!
10-18-2012, 11:53 AM
#31
[QUOTE=Homeboy981;309696]@blair,
It could be better and I'll take suggesttions but there is so little room to make a 90' turn coming out of the TB before you hit the rim of the engine bay. There was a small tab on that rim...I ground it off...needed that 1/2' !!
TB won't rotate any lower to miss the rim. So yes a little restricted.
10-18-2012, 12:09 PM
#32
1999 base
thanks for the update Blair.
a little bit disappointment that the numbers are so much apart then what is posted on the Pedro website. (+30HP)
with that said, he dose recommend a use of high performance exhaust system for best results.
i think ill give it a try anyway.
the plan as i mentioned earlier, is to go catless.
i think i will run a dyno as it is today (TS bypass pipe and de shnork)
and once again after installing:
the full thechnopwoer2 kit
UDP
headers
modified exhaust.
if ill get +20, its worth it.
10-18-2012, 12:50 PM
#33
UDP
headers
modified exhaust.
The way I read this is he's got 26+WHP from stock (which is well over 30BHP from the stock 250BHP). The Fabspeed might help a bit by deleting the secondary cats, but I doubt the muffler has any bearing on performance. This actually appears to be a worthwhile mod. Not cheap, but if $1500 gets close to a 26WHP gain without altering drivability or emissions...then it's not horrible either. A 986 with 280ish on tap is going to feel very lively indeed. That about 10lbs per hp as opposed to over 11lbs per hp for stock.
10-18-2012, 01:11 PM
#34
It's a 550 anniversary....so he started with the factory quoted number of about 260 or so
986 00S
10-18-2012, 01:12 PM
#35
Homeboy981
[QUOTE=blair206;309732]
Originally Posted by Homeboy981
@blair,
@Blair, Good post! Good info…and a bit of a reality check for me since I thought we would GAIN more HP from those mods. Again, that is Mfr. promises vs. ACTUAL WHP. I understand.
Seems to me if the airflow is straightened out a bit it may help. Have you tried a 45 degree up to that TB? You ARE USING a 4" (or 102mm) tubing, right? It seems you may get more clearance by going across instead of over. Just an opinion - it may not work. That is where I am with that. Also, the honeycomb mod is SUPPOSED to straighten airflow which would allow the MAF better calculations. It is not a "sawtooth" looking linear chart and more straight line (see thread below for more clarification - it's long but enlightening).
Also, are you using the ENTIRE 3" x 5" area (where the snork used to be) as the "intake pipe" or it that air being further reduced?
Keep up the good posts, very educational!
Reason: left something out
10-18-2012, 01:22 PM
#36
12 hp gain at the wheels. realise that 5 of that is UDP, which means 7 hp from cat back, tb/plenum, tune. that's a lot of lettuce for 7 hp.
10-18-2012, 03:03 PM
#37
I think after market headers with sports cats would up the number. I've steered clear of those because of cost and drone.
Also my gain is 20/13 hp. If we believe we lose 15% power from crank to wheels.
Stock was 264 hp at the crank = 224 hp at the wheels.
Moded is 284 hp at the crank = 241 hp at the wheels.
Don't forget the car does have 55,000 miles on it to. I don't it would still be putting out 264 hp on 93% humidity day.
The car is noticably faster and sounds great. I don't regret doing the mods, most I did myself and had fun doing them. But I am thinking of getting new headers now !! lol
10-18-2012, 04:26 PM
#38
Nice write up, thank you.
