Old 10-15-2012, 09:18 PM   #21
Track rat
Topless's Avatar
Originally Posted by mcomet View Post
Btw does anyone have any pictures or info on how to properly measure the rotors? I have a digital caliper/micrometer. I assume the wheels have to come off for this? I know I will need brakes but I am concerned if I DIY then I won't know if rotors are bad...
Often you can just reach through the wheel to measure rotor minimum thickness with your mic. The minimum runout is normally stamped on the rotor hat. If they are close to min. I always change them. I generally change the rotors every other pad change. A set of cheapie Balo rotors is about $120 while OEM Zimmermans are about $180/pr. Fresh pads and rotors are sweet!
Old 10-16-2012, 03:56 AM   #22
Jaxonalden's Avatar
A $200 oil change? I guess they top the windshield washer fluid off with Perrie?
This is a good reminder why I do all my own maintenance.
Old 10-16-2012, 08:12 AM   #23
Which of course explains the oil stains on your driveway.
http://986forum.com/forums/general-discussions/37191-strange-sound-puddle-oil.html
And I think you meant to say Perrier.
'99 black 986
