Old 09-18-2012, 08:46 PM   #1
Question Need some help on the short shafts.
I have been having some sqeling on the rear end. I had a friend look at the car on the lift with me in and had the car in gear and he is telling me that it is the rear bearing in or around the Trans. Where they go in to the trans. Ok he is a back yard mechanic and is saying that the trans need to come out and the bearings need to be replaced? First I need to know on the trans is their bearings for the output for the sort shafts. Second can I do this my self with the car on jack stands and the trans in the car.
davetheviking is offline   Reply With Quote
Old 09-19-2012, 08:46 AM   #2
Go get another opinion...not enough information here to help you with.
If youe buddy is referring to the inner CV joints, you do not have to remove the transmission. Not sure about the referral to bearings.
dghii is online now   Reply With Quote
Old 09-19-2012, 09:31 AM   #3
Bruce Wayne's Avatar
but if you are going to remove the gearbox.. do the IMS and RMS you'll be kicking yourself if you don't.
986 x2 6sp
2x Range Rover Vogue 4.6
2004 MX5 Sport 6speed Strato Blue (wifelet)
2x Range Rover Classic & CSK
Bruce Wayne is offline   Reply With Quote
Old 09-20-2012, 09:15 PM   #4
what is the rms. I know about the interm. shaft.
if you look at the tarns by its self. you will see a place where the cv joint is bolted on to the trans that is call the output shaft from the trans. this may be a BMW term but that is what I know for now
Old 09-21-2012, 04:52 AM   #5
RMS = Rear Main Seal
IMSB = Intermediate Shaft Bearing.
Mileage? Year? Model? If your getting any noise at the rear of the engine, I would isolate it with a stethoscope. A member recently found the cause of his squealing to be a loose spark plug. However, it could be a number of things...
shadrach74 is offline   Reply With Quote
