Old 09-16-2012, 02:18 AM   #1
Rear glass window defroster fell off
On my 2003 Boxster S, there are 2 attachments to the glass, one on each side. One side fell off. What can I use to reapply the defroster to the window.
ohhh my is offline   Reply With Quote
Old 09-16-2012, 09:05 AM   #2
dan.oneufer's Avatar
I had the same problem and found an adhesive made just for this purpose at a chain auto parts store. It held just fine, but the defroster does not seem to work. I have not tried checking the wiring back to the switch yet to see if the failure is elsewhere.
2003 Boxster S Dark Teal
dan.oneufer is offline   Reply With Quote
Old 09-16-2012, 12:14 PM   #3
Theoretical propagandist
Eric G's Avatar
Autozone has a copper based solution that is designed to repair broken defroster lines and restore connectivity. Cost was only about 6 bucks.
Old 09-18-2012, 06:37 AM   #4
solder. unless the ribbon came off too, then replace the glass or try the copper based stuff Eric G is talking about
Mighty Shilling is offline   Reply With Quote
Old 09-19-2012, 07:40 AM   #5
Nimbus117's Avatar
I used the tab repair kit off here when mine broke:
Frost Fighter Online Catalog
It's a silver based epoxy, works really well.
Nimbus117 is offline   Reply With Quote
