Old 09-05-2012, 06:54 AM   #1
dagdisco03's Avatar
There are 3 micro switches. Inside door handle, Outside door handle and the door latch assembly. Each does it's own thing. Pull inside handle window should go down 1/2 inch. Release handle window should stay down. If you let go of the handle and the window goes up it's the micro switch in the latch assembly.
Same for the outside if you are pulling the handle on the outside and the window does not go down it's the outside handle. If it goes down and back up with the release of the handle it's the latch that has the issue.
I don't think there is timing involved. If I open a door the window stays down forever until I close the door.
2000 Boxster S
dagdisco03 is offline   Reply With Quote
Old 09-05-2012, 07:21 AM   #2
97 Boxster's Avatar
Dag, can I just get the microswitches?
2006 Hummer H3 - RED 76k mi - LIFTED - 3rd row custom seating on 35's and a manual tranny.
1997 Boxster Guards - RED 86k mi - 19" Lobster Claw Wheels on Conti's , Porsche side decal for extra "speed", manual tranny -signed by Hurley Haywood
Phoenix, Arizona
97 Boxster is offline   Reply With Quote
Old 09-05-2012, 02:11 PM   #3
dagdisco03's Avatar
Only the switch for the outside handle is sold on it's own. PN# 996-613-126-00
or 996-613-125-00
Inside handle and latch are full assemblies. I think the latch is the most common to go.
2000 Boxster S
Old 03-11-2014, 10:03 AM   #4
2002 Boxster
Hi, what is it then if the window just doesn't go up once you close the door, it just stays down ?
Is it the latch ?
Terry
TerryT is offline   Reply With Quote
