DYI Shift cable ends.
Made this up today. They work better than the original.
http://986forum.com/forums/uploads01...1344540877.jpghttp://986forum.com/forums/uploads01...1344541048.jpg http://986forum.com/forums/uploads01...1344541095.jpg |
You might want to check but I think the plastic ends are designed to break purposely in order to protect more expensive components or prevent the top from racking or bending.
The cable is held in with a set screw, it will pull away with that kind of force. The end is held with a heavy metal clip attached to the transmission. A new Porsche shift cable is $$$$$$$$$$$$$$$$$.
Nice work! ;)
My first wife was an Engineer Physicist, she was not slow more like psycho :troll: |
Always fun and rewarding to engineer something yourself! ;)
My shift cables are held on with zip ties... And it's been that way for years.
Nice Solution!
Perhaps you could use something similar to the Short Shifter Linkage. It is an aluminum block that replaces the plastic part on the OTHER END of the shift cable (near the shift lever in the cockpit). It was one of the most common points of failure for racers so it was done when I put in the Short Shift Kit in there. Here is a pic: http://www.****************************************.com/UserData/Images/Large/208315.jpg The aluminum "block" with a plastic cup piece is held in place by 3 allen bolts that tighten around the cable so it cannot slip. It can adjust the cable length too somewhat. Also, being one piece, it should be stronger too. They are available for $44. May not work on this application though...Just a thought. |
I am thinking of the shift linkage also, compared to the AP one below which would be best in your (or others) opinion? http://986forum.com/forums/uploads01...1344609631.jpg |
Here you go, but also at Amazon, eBay and others:
Agency Power |
| All times are GMT -8. The time now is 03:54 PM. |
