Old 08-08-2012, 06:47 AM   #1
Warm the engine driving or in the driveway?
Just wondering what was better, to warm the engine idling in the driveway OR to gently drive it until it gets to normal operating temp? Please fill me in.
986Porsche986 is offline   Reply With Quote
Old 08-08-2012, 06:58 AM   #2
Driving ....
seventythree is offline   Reply With Quote
Old 08-08-2012, 07:15 AM   #3
Ex Esso kid
gentle driving till warm, that's what the manual states or something like that.
Old 08-08-2012, 07:28 AM   #4
Driving. Do a search, there's several threads on the subject.
Old 08-08-2012, 07:41 AM   #5
DIY extremist
black_box's Avatar
turn on engine, put on belts, drop top, play with radio / nav / HVAC, check mirrors, slowly engage 1st / reverse, go. Prob good idea to let it idle at least 30s before pulling out IMHO.
"Betty" -- 2000 Boxster S, Triple Black, loaded except PSM (sold to a good home)
"Veronica" -- 2008 Boxster S, Arctic Silver on Blue
"Maleficent" -- 2007 Cayman S, Red and Black, TPC Turbo 3.6L 460 RWHP, H&R RSS Coilover / TPC stage 2 suspension
black_box is offline   Reply With Quote
Old 08-08-2012, 07:45 AM   #6
Carnut
AndyA6's Avatar
Drive! 1,000,000,000 %
Endless disussions about this topic on all kinds of forums etc etc.
'14 Boxster
Old 08-08-2012, 08:10 AM   #7
Driving gently. Short shift. I don't exceed 3K rpm until the engine is warm.
Old 08-08-2012, 08:14 AM   #8
Johnny Danger's Avatar
Somewhere I read that holding a hairdryer over the engine for a few minutes before driving works great .
Old 08-08-2012, 08:19 AM   #9
SoK
i run mine sitting until the rpm's drop (out of cold cycle) and go no higher than 3500 until it's warm.
2001 Seal Gray 5-Speed - 2007 Yamaha R6 - 2003 Honda Civic EX - 1999 Nissan Frontier XE - 2003 Coleman Utah
SoK is offline   Reply With Quote
Old 08-08-2012, 08:20 AM   #10
CoBeerToad's Avatar
I believe this is correct only when used in conjecture with putting your keys in the freezer before starting the car.
CoBeerToad is offline   Reply With Quote
Old 08-08-2012, 08:56 AM   #11
Wow!!! Thanks for the input. I have been doing it all wrong all these years. I just hope no one wants to race me just after I pull out of my driveway.
Old 08-08-2012, 09:18 AM   #12
Opposed to Subie Burble
Overdrive's Avatar
Manual says drive the car immediately after starting. Don't apply full throttle, don't exceed 80% throttle, and don't exceed 4,000rpms, until the car reaches operating temperature...then you can drive it however you want.
-O/D
IMSR + RMS
Robbins glass window top
Old 08-08-2012, 09:37 AM   #13
Ex Esso kid
Well Mr. Shecky Green, back when we used to have winter we installed plenty of these.
I sheared off a shift pin on an X19 that sat one week on the shore of Ontario, it was standing still warmed up when it happened, that's how viscous the gear fluid got.
Old 08-08-2012, 10:20 AM   #14
I usually let idle for 20-30 seconds then bring rpms up to 2500 for 5 seconds or so before taking off. If I don't bring rpms up first, it surges and lurches on first take off.
Old 08-08-2012, 11:46 AM   #15
l3m
l3m's Avatar
Driving immediately also warms up the transmission.
'01 S
l3m is online now   Reply With Quote
Old 08-09-2012, 07:03 AM   #16
New York, eh? I can tell you live in a sub-tropical climate as you only have one cord coming out of the grill. Up here we'd have dual block heaters, a battery blanket, and an interior warmer, and we'd still have to put a pan of hot coals under the oil pan for 15 minutes and spray ether into the air intake before starting it.
Howling winds, deep snow, freezing temperatures... and when we get outside it's even worse!
'99 black 986
Old 08-09-2012, 07:43 AM   #17
BYprodriver's Avatar
The object of the game is to minimize the load on the driveline until it is at operating temperature. How in the hell anyone can think driving is less of a load than idling where you start it is beyond me.
Old 08-09-2012, 08:29 AM   #18
SoK
That's what I was always told. Why operate something that's not at least out of the cold cycle? I usually let mine run for a few minutes when cold, even in the dead of summer, before i take off.
Old 08-09-2012, 09:00 AM   #19
Yet Porsche, in the owner's manual, specifically states that you should not let the car sit and idle when you start it and that you should immediately drive off. There must be some reason for them to make a point of saying that.
'99 black 986
Old 08-09-2012, 09:21 AM   #20
Is there any scientific basis for the 2500rpm number that has been posted a number of times? Just to be clear we are running modern engines, with modern synthetic oils (hopefully)... I can see no logical or scientific reason to stay under 2500 RPM. If the system has oil pressure, then there should be no metal to metal contact. Certainly full throttle or Red line ops are a no-no until the fluids are warm, because that may generate oil pressures that are higher than factory parameters. Also, in extreme temps, dissimilar metals contract and expand at different rates. Metal to Metal interference form this phenomenon is highly unlikely, but is still something that we should keep in mind.
2500, 3000, Idle...whatever. The factory says 4K is the limit cold and there is likely some scientific reason for that...other than someone on an internet forum said it once and 25 people repeated it.
shadrach74 is offline   Reply With Quote
