Old 08-08-2012, 03:55 AM   #1
When changing the AOS....
what is the HOSE CLAMP TOOL folks are recommending? Where can you buy one?
Soetekouw is offline   Reply With Quote
Old 08-08-2012, 05:10 AM   #2
This is what I bought.
Amazon.com: OTC 4525 Cable-Type Flexible Hose Clamp Pliers: Automotive
mikehkang is offline   Reply With Quote
Old 08-08-2012, 05:36 AM   #3
Theoretical propagandist
Eric G's Avatar
Thanks Mike...just ordered mine as that is a killer price!
Old 08-08-2012, 10:39 AM   #4
Thank you. Placed an order for this, too. Now I just have to figure out how to use it.
Old 08-08-2012, 10:46 AM   #5
jcb986's Avatar
You really didn't need it. Most of us replace the clamp type with screw clamp which is much easier to get back on than the clamp type.
Old Hippie Young Heart
Old 08-08-2012, 11:18 AM   #6
If you can squeeze, you already know how.
Old 08-08-2012, 05:22 PM   #7
Makes sense replacing the clamp type with the screw type clamp after you get the clamp off. But isn't the reason to get this tool because taking off the clamp type is one of the hardest things to do?
Old 08-08-2012, 05:49 PM   #8
I've done a few of these and you don't really need to remove the clamp. Each AOS I've bought comes with a new hose. I just cut the the old hose, remove the AOS out of the way. Once this is done you have clear access to the hose and clamps.
When installing I use a regular hose clamps and use a socket, long extention and ratchet to tighten. It's much easier to install and remove in the future.
2008 Boxster S PDE2
cas951 is offline   Reply With Quote
Old 08-09-2012, 05:52 AM   #9
That tool is worth its weight in gold. There are spring clamps all over this car and some of them can be a real bear to get off because of access. This tool makes it too easy and, if you have it, there is no need to start replacing all your spring clamps with screw-type hose clamps. Another great tool in the same department is the Snap-On round wire spring clamp pliers.
'99 black 986
