Old 07-13-2012, 05:40 PM   #1
Stripped coil pack bolt
Any suggestions? Just bought the car (02 S) and tried to change the plugs and tubes only to find that one of the coil pack bolts is stripped. Can't get a drill in there and it's pretty much round. All the others were fine.
Stumped on this one.
sfoster13 is offline   Reply With Quote
Old 07-13-2012, 06:05 PM   #2
copsahl's Avatar
Can you tap it out and replace the bolt?
copsahl is offline   Reply With Quote
Old 07-13-2012, 06:11 PM   #3
Bmod986's Avatar
Your best bet is to use a vice plier, because I don't think you have space to wield a nut to it. So use a vice plier with sharp teeth and loosen it up then it should come off by hand after the initial turn. Hope this helps.
Bmod986 is offline   Reply With Quote
Old 07-13-2012, 06:26 PM   #4
space is the issue. can't tap it and can't weld it. it's the top bolt middle of the driver's side bank.
will try vice pliers
