Old 07-08-2012, 07:27 AM   #1
knocking from engine boxster s
hi all, i have a boxster s 3.2 2001, i have a knocking from the engine only when the temp is up, i think its the oil once it gets up to temp it thins out and then the knocking starts, im using 5w40 mobil 1, any ideas before i change to 10w40 oil? cheers
RICHARD X is offline   Reply With Quote
Old 07-08-2012, 09:28 AM   #2
Once the engine (and oil) is warm, a 5w40 oil should have more than enough viscosity to protect the engine (its not likely "thinning out" unless your engine temp is over 250). Changing to a 10w40 will not likely improve the viscosity (its 40 in both oils when warm).
The first thing that I would do is to have your front engine mount inspected, its probably worn out and making a knocking noise.
Old 07-08-2012, 10:07 AM   #3
jaykay's Avatar
Detonation or ticking/valve train noise?
986 00S
Old 07-08-2012, 10:47 AM   #4
it only knocks when its up to temp and idleling, as soon as i put my foot down a bit it stops (when in motion there is no knocking)
Old 07-08-2012, 11:30 AM   #5
2 fast 4 U
Are you using at least 93 octane fuel. I once put in 91 octane in my Boxster by accident and I notice knocking at idle speed.
Drive it the way it's meant to be driven!
2000 Boxster S
redeye280z is offline   Reply With Quote
Old 07-08-2012, 11:49 AM   #6
Engine Surgeon
Is the knock most notable @2,700 RPM?
US Patent 8,992,089 &
US Patent 9,416,697
Old 07-08-2012, 11:56 PM   #7
no the knocking only sounds when its up to temp and idleling/tick-over, when i put my foot on the acc it stops, my thoughts are that the oil is thining out when temp is up and when i put my foot down more oil go in and stops the knocking,,
Old 07-09-2012, 12:51 AM   #8
Detonation, valve, or crank? Should be able to tell from the sound and where its coming from. A "tick" is probably valve related, but hard to say. You should post some audio/video.
I seriously doubt that its the oil viscosity.
Old 07-09-2012, 10:24 AM   #9
Does the knocking change if you press in the clutch?
Old 07-09-2012, 12:10 PM   #10
My engine knock turned out to be the water pump getting wobbly.
Wret is offline   Reply With Quote
Old 07-09-2012, 01:25 PM   #11
jaykay's Avatar
A light tick at idle may be injector noise
986 00S
Old 07-09-2012, 01:48 PM   #12
Does it sound anything like this: Clicking sound from engine bay - 2006 Cayman S - YouTube
ChimpanZed is offline   Reply With Quote
Old 07-13-2012, 06:28 AM   #13
it does not sound like a light injector tick, more of a knock, only happens when on tick-over around 800rpm and when car is up to temp, when 1st start and cold it purrrrs like a cat!!, the car is an auto-tiptronic, if its a mechanical problem sureley it would happen when i 1st start the car and happen all the time,, im gonna change the oil to a higher viscosity to see what happens!!
Old 07-26-2012, 09:39 AM   #14
knocking on the wall?
Is that sort of knocking on the wall behind seats? It's heard after 10 or 15 minutes of warming up, specially while going on non-so-flat roads, more intense when stepping up accel. pedal, so to say...
josefer is offline   Reply With Quote
