Old 11-19-2013, 03:03 AM   #21
bobbyg's Avatar
Thanks guys for this info. I try some of the advices tomorrow.
I had this problem started two days ago. At first it started honking every time I drive on top of a speed bump, at very low speed, and then, even while turning at corners or roundabout. At one stage I felt so very embarrassed. going to work, turning at a roundabout with a fair bit of traffic, it started honking again, and damn it's loud!! Roof top down, there was no escaping the look on everybody's faces looking at me as if I'm the village idiot, in a Porsche!!! lol
So much for a Porsche ey? :-).
Cheers and thanks again for the good work guys.
bobbyg is offline   Reply With Quote
Old 11-19-2013, 05:05 AM   #22
Originally Posted by vath2001 View Post
Airbag bracket. The bushing are wearing out. Two options: Try to use some hose or tubing to reinforce the bushing... or spend $60 buck at Suncoast Porsche for a new bracket.
I wedged a piece of thin black cardboard in the gap at the top of the wheel....that was 2 years ago...horn still works when I want it to but no longer lets me know every time I run over a dime...
1998 986 with ladder racks.
paintboy is offline   Reply With Quote
Old 05-13-2015, 01:11 PM   #23
Rburro2
rburro2's Avatar
I recently bought a 2000 Boxster. I noticed the horn didn't work. So I checked fuse B3 and it was blown. When I replaced the fuse the horn was as if someone was holding it on, without the steering wheel being touched, until the fuse blew again. Obviously there is a horn switch in the steering wheel. Will the rubber bushing behind the bracket cause this?
2000 Boxster 2.7- First Porsche Owned
rburro2 is offline   Reply With Quote
Old 05-13-2015, 01:20 PM   #24
Pdwight's Avatar
Not too get to elektronikal
But most folks have no idea how much current a horn uses when that giant buzzer is running....it is substantial ....many amps
Old 05-13-2015, 07:08 PM   #25
Registered Boxster abuser
healthservices's Avatar
When the air bag frame makes contact with the ground in the steering wheel this is what makes the horn blow. So yes the rubber bushing is part of the horn switch, it is what holds the air bag frame from grounding out.
Old 05-13-2015, 07:23 PM   #26
Pdwight's Avatar
I thought the IMS held it in place
Old 05-14-2015, 04:18 PM   #27
If you are thinking that the rotors are worn out and causing the issue, maybe you should email ECS first.
Old 05-14-2015, 07:04 PM   #28
Pdwight's Avatar
Actually
I was thinking a combination of roller and ball bearings interlaced might be the solution
Old 05-14-2015, 07:22 PM   #29
If anyones horns are actually inop let me know. Im literally about to install hella horns on mine.
antny is offline   Reply With Quote
Old 05-14-2015, 07:44 PM   #30
Pdwight's Avatar
hella you say
Old 05-14-2015, 10:21 PM   #31
HAHA, have you heard Hella Supertones before? They are significantly louder than stock horns.
