Thread: Horn Problem
Old 05-13-2015, 07:08 PM   #25
healthservices
Registered Boxster abuser
healthservices's Avatar
Originally Posted by rburro2 View Post
I recently bought a 2000 Boxster. I noticed the horn didn't work. So I checked fuse B3 and it was blown. When I replaced the fuse the horn was as if someone was holding it on, without the steering wheel being touched, until the fuse blew again. Obviously there is a horn switch in the steering wheel. Will the rubber bushing behind the bracket cause this?
When the air bag frame makes contact with the ground in the steering wheel this is what makes the horn blow. So yes the rubber bushing is part of the horn switch, it is what holds the air bag frame from grounding out.
