Old 05-04-2012, 07:38 AM   #1
smagerstein's Avatar
Cat Back exhaust system. Thoughts??
Hi there,
Do you guys think its worth trying this out? Its not that expensive to try. Im after a bit deeper sound and I think much nicer looking.
PORSCHE BOXSTER 986 2.7 96-04 STAINLESS STEEL CAT BACK EXHAUST SYSTEM BACK BOX | eBay
Steven Magerstein
2002 Boxster 2.7 Seal Grey
2008 MB C200k
Past Cars
2006 MB C180k
2005 Peugeot 306
1980 928
2004 Subaru Liberty GT
2000 Nissan Pulsar SSS
smagerstein is offline   Reply With Quote
Old 05-04-2012, 08:01 AM   #2
Stand by for the teeth rattling drone problem…………………
Old 05-04-2012, 08:07 AM   #3
Johnny Danger's Avatar
Originally Posted by smagerstein View Post
Hi there,
You should do a search on the forum for Charlie Chan muffler .
Old 05-04-2012, 09:29 AM   #4
Is that the exhaust, discussed a while back, that had one of the the tips welded 1/4" higher than the other?
IIRC, each one had to be cut and re welded or some such, else wise the back of the car looked like you just installed an exhaust you got of ebay.
RobbieKnobbie is offline   Reply With Quote
Old 05-04-2012, 02:37 PM   #5
The main problem with aftermarket Boxster exhausts has always been a ghastly harmonic droning effect inside the car at typical highway speeds. Porsche sport exhausts for the 986 addressed the problem by adding small diameter muffler bypass pipes with some kind of vacuum-assisted valve opening mechanism. It avoids the drone, but is way expensive.
A while back, some folks were adding small bypass pipes to stock mufflers with some success, but you have to be pretty handy with a welder to do that, or know someone who is.
spdshift is offline   Reply With Quote
Old 05-04-2012, 03:49 PM   #6
I have that same exhaust in my car now. It's super light, so u would definitely lose some good pounds. it does improve sound but not as loud as I'd like ( I do have the evo intake and my car is desnorkled). Which is why I'm picking up a used GHL next weekend. I didn't notice any drone with the exhaust. If you're interested, pm me and I will let it go cheap!
Blue 2003 Boxster S
GT2 Front bumper
GT3 Side Skirts
19" MHT Rims
Evo Intake, De-Snorkeled
CVstarBoxster is offline   Reply With Quote
Old 05-05-2012, 12:18 PM   #7
I don't get the tip angle on those mufflers. When I put my system together I found that the tubes to the tips need to angle down and then a 2nd set of bends was needed to make the tips horizontal and at the right height, otherwise they would be pointing downward.
Wret is offline   Reply With Quote
Old 05-06-2012, 06:58 AM   #8
ChrisZang's Avatar
I just installed the same exhaust (see my other posts) and the exhaust has no drone at all
Old 05-08-2012, 02:18 AM   #9
I have a similar styled exhaust, no drone problems great sound and noticed power gain, installing headers this week, & had computer remapped, no complaints.
gilmanco is offline   Reply With Quote
