Old 04-26-2012, 10:54 AM   #1
jaykay's Avatar
Power steering fluid
What is considered to be the best power steering fluid for the Boxster theses days?
I have heard that some use redline...
986 00S
Old 04-26-2012, 11:29 AM   #2
Pentosin CHF11.S is the correct fluid for the car, most NAPA stores carry it. You need to note that it is not compatible with many other fluids, but as it is a full synthetic, it does an excellent job.
Old 04-26-2012, 11:38 AM   #3
You can kind of flush the system by jacking up the front end, removing as much fluid out of the reservoir as you can with a syringe/turkey baster, refilling, starting the car and turning the wheel gently, lock to lock a couple of times. Repeat until you have run through about 3/4 of the can of fluid, save the rest for top ups.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 04-26-2012, 12:04 PM   #4
ChrisZang's Avatar
LN Engineering seems to believe that RedLine is the best
Old 04-26-2012, 12:24 PM   #5
jaykay's Avatar
Yes I need to flush, replace, add fluid as I am getting some groaning on full lock....I have a UDP as well.
Thanks for fluid recommendations. I will check the LN site as well
I suppose jacking will bring stagnant fluid out of the rack area but I generally don't ever run the car on stands....can it be purged without running the car?
986 00S
Old 04-26-2012, 12:25 PM   #6
Redline
I read that on LN site, and went for it in mine. I now have 1500 miles on my rebuilt engine, and no issues with the steering pump. I actually think it works better, but that could be the quality and $ dealer alignment.
onaFLYer is offline   Reply With Quote
Old 04-26-2012, 12:27 PM   #7
Not without disconnecting some fluid lines, that I know of. Its no big deal to run the car on stands, you are not going to be getting underneath it.
Current car
Previous cars
1973 Opel Manta
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1993 Saab 9000
Old 04-26-2012, 01:11 PM   #8
ChrisZang's Avatar
While you're at it why don't you buy & install the LN Engineering PS cooler
You'll get the RedLine fluid included and you will have to drain all the old fluid ...
Old 04-26-2012, 07:26 PM   #9
Jaykay, If you're in Toronto and go with Pentosin, Pfaff Porsche in Woodbridge sells it for $29/liter. That's half the price NAPA sells it for.
rdc8118 is offline   Reply With Quote
Old 04-26-2012, 09:46 PM   #10
Idaho Red Rocket 3's Avatar
Follow JFP recommendation. Stick with the Pentosin CHF 11. IMHO.
2000 Boxster S
Old 08-08-2014, 11:23 PM   #11
DennisAN's Avatar
I'm used to doing this on other cars, BUT the Boxster has long PS lines going up and back from the front of the car. The factory manual says capacity for the PS system is 1.0 liter (of Pentosin CHF 11 S). But I was only able to suck out and refill 20 cc of fluid from the PS reservoir today. That's only 2% of the system. At this rate a dozen repeats of suck and refill may only change about 20% of the fluid.
Is there any trick to getting more than 20 cc out of the reservoir? I used a large syringe with a clear vinyl tube extension.
Base 2000 986, beater 1996 Miata, 2011 Suzuki SX4 AWD
Feline mechanics Condoleezza and Dukie
DennisAN is offline   Reply With Quote
